Congratulations !!
You're just been pimped
YOUR BASKET
1 x Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) £329.99
1 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £280.00
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Toshiba SSD HG5D Series THNSNH 7mm 256GB Solid State Hard Drive - (THNSNH256GCST) £163.99
1 x Corsair Graphite 600T Midi Tower Case - Limited Edition White £145.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Corsair Professional Series HX+ 850W '80+ Gold' Modular Power Supply (CP-9020032-UK) £129.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £69.95
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (CMY8GX3M2A1600C9) £67.99
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (CMY8GX3M2A1600C9B) £67.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Warranty £39.95
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
Total : £1,800.29 (includes shipping : £25.45).
Congratulations !!
YOUR BASKET
That's Purdy, but you missed a keyboard..
and why did you go for a more expensive case?
I'd personally get a windowed 300R or wait for the Bitfenix Ronin, both £70.
And that PSU? Nice but OTT.. I'd get the XFX over that (750W version)
Just for you Doomspeed
YOUR BASKET
1 x XFX Pro Series 750W XXX Edition Modular '80 Plus Bronze' Power Supply £85.99
1 x CM Storm Quickfire Rapid Mechanical Gaming Keyboard - Black Switch £69.98
1 x Corsair Carbide 300R Mid Tower Windowed Case - Black £69.95
1 x CM Storm Recon 4000 DPI Gaming Mouse £39.98
Total : £1,790.26 (includes shipping : £25.45).
thanks a lot guys! but is that screen you choose better than the initial one i had?
It's a 27" 120Hz rather than a 24" 144Hz. Personally I would rather have the extra screen size as I recon' you would be hard pressed to detect a difference between 120 and 144Hz. And in most modern games if you max them out, you wont be getting a solid 120/144 fps anyway. (even with a 780)
But then again it is a hefty amount more expensive.
Very nice. Oh, and the window on the 600T is not too small. It's bigger than it looks because the case is too![]()
Myself personally would rather get the biggest 60Hz monitor I could and lose the TN panel, for a nice IPS one![]()
