My son (15 months) has discovered the switches on my HAF-X.
Appreciate I can take the reset off the header and disable the power button in Windows.
But does anyone have an idea for external one?
try to take the power switch off the case and put it behind the computer, and to replace the space put a paper on there
EDIT:
some example for help, just search with this images on the internet
i hope that i helped
the reset you could disconnect from the mobo, so it will not make any space on the case, the power i found one on the net, but is not from the overclockers, so shall i post the link?
MHD
Don't hotlink, save locally and host yourself!! Mods'll get you.
