Skeeter and Muffin on here run CL Pads (Carbon Lorraine) RC5+, they like them, and they'll be going on my car soon!
As for fluid, Motul RBF600 gets good reviews, OR if you can afford it.. then buy some Castrol SRF. It's the best fluid going, Excellent Dry&Wet boiling points!
Ran RC5+ pads for 2 years and they are still hardly used. They have eaten away my plain Bembo discs though, but over 2years and £50 for a pair, that really is a moot point.
Forget wasting money on RBF600, pickup ATE Super Racing Blue. Excellent Dry/Wet boiling temps and much cheaper than the above. You can also buy it in blue/orange, so when changing your fluid you can alternate colours to be sure the system has been fully purged of the old stuff.
ATe Super blue for me, cheap and really good.
CL are good but they are a proper metal sintered pad hence they kill your discs, make a lot of noise and shower the sides of the car in metallic brake dust. Most drivers don't want that stuff for their road cars.
They might be noiser than other pads, but they stop like kings and make you sound like RACE CAR
The shower of brake dust over the car comment is also not true. The dust gets all over your wheels, but really doesn't pose problems with your precious paint. I hardly wash my car compared to others and even after 2 years my soft Honda paint is still fine!
RC5+ for me.
