Personally I think they may have got the dual wrong......... don't forget you can change the hardware info. to show whatever you want and can also disable 2 threads etc.
Either way, it doesn't bother me in the slightest as there will be zero difference between quad and dual S4 pro (my one s feels just as fast as most quad core phones and am sure once it gets sense v5/4.2.2, it will be
very hard to tell the difference between it and the htc one [and it is using the dual krait s4 cpu with adreno 225, 1GB RAM])
At least it still has the adreno 320 GPU (which is more important for gaming) and @720P, that will be more than enough with 2GB RAM.
A smooth experience is more to do with software optimisation then the cpu these days.
+100000000000000000000000000000
It seems like moto have concentrated more on the software side of things this time so hopefully they have got every area optimised to be able to get the absolute best out of the hardware.
That is all that we are left with now:
- screen quality i.e. calibration (moto did a good job with their razr phones), brightness, view ability in sunshine etc.
- battery life/size (moto phones usually always excel in this area)
- camera (usually not great in this department, but if the supposed talk/rumours about the camera are true, then it should be very good and possibly even give the GS 4/htc one etc. a run for their money [at least in a few areas anyway])
- sound quality (iirc, they did a good job with the razr phones [not so much the razr i, due to the intel chipset]), obviously it isn't going to be htc one good since it has only 1 tiny speaker on the back though
And price will be the biggest factor, what I have heard is starting to sound a bit too good to be true (assuming the specs are roughly the same for the other version that we will most likely get), but I expect that it will be roughly the same as the nexus 4, no dearer than £300 anyway......
