Hang on, what part of it being a router doesn't work out of the box? When I had fibre installed I told this guy not to bother with the router. I unpacked my sealed TC, plug the wire from the vdsl modem into the correct port, plugged it in, ran the airport utility which a child could handle and I was up and running. Very easy.
Edit, also, all this talk of it not having a modem etc. it's a high end product generally bought by people with a high disposable income, those people will most likely not have your average ADSL instead having fibre or VM which have their own separate modems anyway which is what the TC depends upon. This number is only going to increase anyway so it's a moot point.
In the world that you inhabit fibre might be a reality - however, for most of the geographical UK it's something one can only dream about. I doubt where I live I will see it in my lifetime - so your point is a moot point.
I never said it didn't work out of the box - please please go back and re-read. I said in order for it to work out of the box it's many capabilities are not used.
Had you had a router instead of a modem would you like to provide us with a walk through workshop of just how to turn the TC/AC into a fully fledged router - precise settings etc.?
