** Raijintek High Performance CPU Coolers **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Overclockers UK are delighted to announce that we will be distributing Raijintek in the UK.
Raijintek is a new company that has entered the market with some great cooling designs and we will be working with them closely to bring you their range as it grows.
Raijintek have a long standing background in our industry with a team who have worked at some of the biggest names in the business.
To start off, Raijintek have three very aggressively priced CPU cooling solutions. From an enthusiast point of view, these coolers offer great value as well as strong cooling performance.
We have tested all three in the office and all hold up well to the abuse we have thrown at them.
Go and check out their Facebook Page for updates on new products.
Raijintek Ereboss High Performance CPU Cooler @ £31.99 inc VAT
Ereboss, is a giant heat-sink with world’s top slim type 14013 fan, is an extremely good value cooler. “Designed in Germany”, Ereboss is manufactured to provide users an awesome performance but at a great price point. The Ereboss fan is a slimline 140mm fan at 13mm thickness, but provides outstanding performance.
Key Features
- Nickel copper base, efficient 6mm Heat-pipe*6 & ultra large dissipating area fin
- Super Slim type 14013 PWM fan - 13mm height; Low noise & outstanding air flow as well pressure
- Multiple mounting kits for a wide range of sockets
- Patent designed holes on fins to provide excellent air flow and cooling efficiency
- Dual fans installation option and anti-vibration rubber attached.
Specification
• Dimension: 140(W) x 110.5(D) x 160(H) mm
• Base Material: Nickel Copper
• Fin Material: Aluminum Alloy; Solder-free fins assembly
• Heat-pipe:6pcs.
• Fan Dimension: 140(W) x 150(H) x 13(D) mm
• Voltage Rating 12V
• Starting Voltage 7V
• Speed: 1100 ~ 1650 R.P.M.
• Bearing Type: Sleeve Bearing
• Air Flow: 66.65 CFM (Max.)
• Air Pressure: 1.72 mmH2O (Max.)
• Life Expectance: 40,000 hrs
• Noise Level: 28 dBA
• Connector: 4 pin with PWM
• Weight: 808g (Heat Sink
Only £31.99 inc VAT.
ORDER NOW
Raijintek Themis Direct Contact CPU Cooler @ £21.95 inc VAT
Themis is designed in Germany and manufactured to reach advanced performance, high quality & workmanship.
Themis is a slim type 120mm cooler (D:50mm) and height is 157mm, This cooler is ideal for most ATX chassis. With Anti-vibration rubbers and supporting all modern sockets, Themis is the ultimate choice at a budget price.
Key Features
- Non-Copper base design (C.D.C. - CPU Direct Contact)
- Patented pressing heat-pipe / fin technology to prevent heat-pipe damage risk
- Patented Solder-less louver fin assembly for heat-pipe ventilation increased
- Compatible with all modern sockets of INTEL& AMD
- Anti-Vibration rubbers used to minimize vibration
- Large dissipating area & Elegant design
Specification
• Dimension: 122(W) x 50(D) x 157(H) mm
• Base Material: CPU Direct Contact (C.D.C.)
• Fin Material: Aluminum Alloy; Solder-less fins assembly
• Heat-pipe: ƒ³8mm
• Fan Dimension: 120(W) x 120(H) x 25(D) mm
• Voltage Rating: 12V
• Starting Voltage: 7V
• Speed: 1000 ~ 1800 R.P.M.
• Air Flow: 78.82 CFM (Max.)
• Air Pressure: 3.22 mmH2O (Max.)
• Noise Level: 27.86 dBA (Max.)
• Weight: 448 g (Heat Sink Only)
Only £21.95 inc VAT.
ORDER NOW
Raijintek Aidos Direct Contact CPU Cooler @ £14.99 inc VAT
ADIOS “Designed in Germany – Made in China”, is a compact size cooler manufactured by several patents to reach advanced performance, quality and environmental protection . With multiple mounting kits and compact size, AIDOS can fit to most cases /boards , a full package and at a budget price point.
Key Features
- Less Junk pollution, an exclusive green environmental protection cooler
- Compatible with all modern sockets of INTEL& AMD at market
- Point of view of budget price
- Easy installation and user friendly
Specification
• Dimension: 95(W) x 55(D) x 136(H) mm
• Heat-pipe: ƒ³6mm
• Fan Dimension: 92(W) x 92(H) x 25(D) mm
• Speed: 1000 ~ 2400 R.P.M.
• Air Flow: 53.02 CFM (Max.)
• Air Pressure: 4.2 mmH2O (Max.)
• Noise Level: 29.8 dBA (Max.)
Only £14.99 inc VAT.
ORDER NOW
Here is a gallery of the products :)
They look good coolers and the price is very good. Are you going to test them?
Also how much is a extra fan for the Ereboss? they look nice and slim something I need.
Looks great for the price!!
These fit the usual sockets? (Store links aren't working yet and item description also doesn't say?)
Tempted for one just to use as a stop gap while I get my loop sorted.
Edit: realised it does say the main Intel and amd sockets, but a list would ease my fears about s2011.
Raijintek coolers fit every socket.
Store links will be live in a moment. can take some time when the servers are busy :rolleyes: :(
We are doing our own internal testing currently but have been waiting for a day where the office wasn't abnormally hot to get some proper results.
initial testing in the sweltering heat has been promising.
there are a few reviews live so far. This is in Italy but can be easily translated in chrome:
http://www.insidehardware.it/hardwa...alta-ad-un-prezzo-entry-level?start=5#content
as for things like the fans etc, they will be available as soon as Raijintek releases them. OcUK are the UK distributor for these products so anything they release will be on our site.
look at the pricing though, thats what sets the products apart. The Ereboss is the most expensive in the range and still costs less than Freezer A30, Brocken and 612S
the Aidos is less than an akasa venom pico and cools better.
That is epic value for money tbh. especially considering they look and feel far more expensive than their price tags suggest.
Interesting looking products, I'm intrigued by the one that looks inspired by the HR02. What's the fin spacing and thickness on these things? can they do a job as passive or extremely low noise coolers? i.e. with only 1-2 case fans at <500rpm
Testing Results
Testing results
4770K [not delidded]
Mount Doom Test
K2MOUNTDOOMTEST.jpg~original
Raijintek Ereboss
EREBOSSTEST.jpg~original
Raijintek Themis
THEMISTEST.jpg~original
Raijintek Aidos
AIDOSTEST.jpg~original
Simplified Rundown:
Mount Doom - 62'C
Raijintek Ereboss - 58'C
Raijintek Themis - 59'C
Raijintek Aidos - 72'C
We are doing some more testing at 4.2GHz at around 1.2v to get some clocked results.
Hi there
They are incredible coolers for the money, the Ereboss outperforms some coolers costing twice as much and is right up there with the very best. Don't be fooled by the price, they really do perform far better than the pricing would suggest. :)
I hear the low profile Ereboss fan is a bit noisy though and what holds it back a bit. could always put a Thermalright TY-147 on it though. Even with the extra £6 for the new fan it's pretty good value
Not really. It depends as I didn't do the tests. Could be that the monitoring was started after the test.
