I bought the Halfords 150pc socket set recently and while using it today noticed something that seems remarkably silly.
I had a particularly tight 12mm bolt to undo, so I had two options - use the 6-sided socket or the 12-sided socket. Simple, use the 6-sided socket to reduce the chance of rounding off the bolt. I then discover that the 6-sided socket uses a 1/4" driver while the 12-sided uses a 3/8" driver (see red/green circles)
Why on earth do they give the socket intended for use with the greatest torque, a tiny driver? They only provide a screwdriver attachment and a tiny ratchet in that size!
And while we're on the topic, why do they only provide a breaker bar in 3/8" size? The only thing they provide in 1/2" size is a ratchet! Are we expected to have these things separately? (Not out of the question)
And the next question is, why don't they provide an adaptor to step up a 1/2" to a 3/4"? They have one the other way round (and I've already got a 1/4" to 3/8" - which I ended up using to undo the bolt) but don't seem to do one to step up to 3/4", which is a shame since I've got a lot of breaker bars in 3/4".
Rant over
Rant over
I need the female bit to be 3/4".
