- 7 Oct 2007
Thanks for all the replies!
Not sure why it keeps leaking, she's checked it thoroughly, and the little air bubbles in the juice show something is not right. If push comes to shove she can use it as a mini lava lamp.
It was the one in your first link!
No, that's part of the base which i assume is stainless.
Thanks all, much appreciated.
Thanks for the reply, and yes it does seem like they have changed the design, although the logo is clearly different and the tip isn't the same. Wife said it is a much tighter draw on this new one, she much prefers the older one.This is the updated version of the ProTank apparently.
http://ukvapers.org/Thread-Protank-v1-v1b-changes-mini
Can you link the one she bought? They have both real and 'copies' on fasttech. Unless it says Kanger in the name it is a copy. real protank and copy of protank
At least that is what I've picked up from UKV.
@Whistleblower, the one on the right, is that a rubber grommet i can see near the bottom of the centre post? as there is none on the left one, are the 2 bases where the coils screw in the same?
I may be wrong but i have noticed on fastttech there is a protank knockoff on the site, but it doesnt say 'Kanger' on the tank or in the description.
Oh and my protank is also the same as the left one.
