Hiya
Quick question regarding mod batteries like Efest 18650 3.7v 2000mAh - do they loose power when stored and not used?
Cheers
Yes they degrade over time, any battery does.
Hiya
Cheers
@Redmogg, when i change flavours on my T2 i usually flush out the tank with water using a syringe, give it a good shake so water comes out through the wick. Empty it, then keep burning the wick until no vaper comes out and u see the coil glow, then leave it overnight for the tank to dry out, works most of the time for me.
iirc pbusardo does it at the end of his Aga T2 review
+1...
...million.
I'm trying other flavours on the Aga T2, using the mesh wick as a dripper. The Apple Tart is great, but better online the ProTank.
trust message sent, i honestly cant say enough good things about simon and his juices, he is a fantastic fella and they are all lovely. A perfect match to go with custard as they are of very similiar high standard![]()
Can anyone comment on using mesh vs silica on the same device? Often wondered what the benefits would be, I've just started rewicking/coiling myself. Will probably put some fine mesh on my next order
There are pros and cons. Mesh gives a better flavour, but is an absolute ******* to set up when you first start using it due to the coil shorting out on the mesh. What atomiser you use will determine how easy/hard that process is. You get better at it with practice though.
Silica is just easy, but if you pump a lot of wattage through the coil you can get a funky taste more easily than with mesh. Also, silica wicks deteriorate after a few rinses (not a big deal since they're easy to replace), whereas mesh wicks seem to last months if you keep cleaning them every now and then.
I'll admit, I'm a convert to mesh since I got my RSST, but there are times I yearn for the simplicity of silica with my Nova!
TY. How on earth do you stop shorts?! I'll check a few videos when I get home
Does anyone know if these are knock-offs?
Wife purchased two Protanks from Fasttech, normally wouldn't assume anything was wrong as they came in the same kind of packaging like the one she got from Apollo (New 2013), but she's having massive leakage problems with them and they're gurgling an awful lot. No such issues with the first one she bought.
You can clearly see there are several differences in design on the below pic (Apollo one on the left, Fasttech on the right), even the Kanger logo isn't etched like the one she got from Apollo.
http://www.karensholidays.co.uk/Provari/FastKanger.png
