Glad it arrived mateMine arrived yesterday, great work!
Keep practicing that potential mark!
, good practice as always!.It's doable, but I'd have to ask for a slightly larger donation (would use about £10 worth of black ink in it lol!)
A3 size, as the reference was CGI it kinda ended up looking half comic/half CGI with the reduced pallet.The Hulk is looking good mate what size is it?
Send donation after I've finished & your happy with the final result, but I've got quite a long waiting list atm - so I'll have to get back to you once I've cleared my current requests.Elmarko so how muc for the pic will send the donation now?
Thanks dude, glad you like it.Finally picked up the Robin Williams pic. Chuffed to bits, just need to pic a frame for it now.
Thanks elmarko!
.Pencil drawn roughly, then detail pencil drawn to split into sections based on tonal ranges & coloured using promarker ink pens (I use photo-shop playing with brightness & contrast to create the layers to draw), I used to do loads graphical design so my approach is a little odd (I take regular measurements as I draw each section compared to that of the reference image) which makes it take allot longer, but keeps the perspective on track.just a quick question are you drawing these from scratch or printing out or using tracing paper and then using the pens or makers to color in?
Glad you got it & you like it mateReceived Tyrion today thank you, looks even better than the photo!
Just need to get a frame for him now.
, black frame with a white inner border usually works best with the monochromatic style according the people at my local art shop the last time I got a couple framed.
If you could take some new ones it would be great - with either a very dark or very light background - good light, reasonable contrast & closer up being the main thingHi mate quality work as usual! Do you think you will be able to do something with the dog pictures I sent you, or should I take some new ones?
.(inbox brimming with requests).
Not really got a fixed limit, just extending the just-giving page as they come in.Not surprised! Have you got a time limit?
If you could take some new ones it would be great - with either a very dark or very light background - good light, reasonable contrast & closer up being the main thing.
Awesome, may be a while waiting due to the long list - all donations are done after it's finished & your happy with it (also due to the fact I can't always give perfect timescales due to other time commitmentsNo problem mate, i'll dust off the dslr and take some new pics.
