Thanks for all the great advice![]()
I have gone over budget to spec the Corsair case as recommended by a few of you,also i have chosen a enermax supply because the one I have at the moment is enermax and it is still going strong after 7 years
Here is what i have in the cart. Tell me what you think.
Cheers
Jim
YOUR BASKET
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £74.99
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £68.99
1 x AMD A8-5600K Black Edition 3.60GHz (Socket FM2) APU Trinity Quad Core Processor **FREE SIMCITY PC GAME** (AD560KWOHJBOX) £67.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) £59.99
1 x Enermax Triathlor 450w '80 Plus Bronze' Power Supply (ETL450AWT) £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £48.95
1 x Corsair Carbide 200R Compact ATX Case - Black £47.95
Total : £434.84 (includes shipping : £10.00).
That's a pretty nice build. If you definitely don't want to do any gaming you can cut back on the RAM speed to save £15 or so. But maybe the free Sim City will convert you![]()
The IGP is good might as well feed it properly. Remember the IGP can accelerate other tasks not just be used for gaming. He could always add a good value heatsink later on and overclock the CPU and IGP to further improve the performance.
For the sake of £15 I wouldn't normally think of it, but I know it's already over budget.
SorryI forgot to mention I have a optical drive.
You know, if you talked a bit more, you could save yourself a tenner.![]()
He said he was driving down there dude. I did hint at the free P&P perks earlier![]()
Off topic, hav`nt seen much of you lately, been on your hols?
Just been busy with life bloke, work and family dramas nothing exciting I'm afraid.
..... family dramas......
Don`t do drama.
I avoid these like the Plague.Don`t do drama.
Just checked the ODD is sata
Can you suggest a alternative mobo in case the Gigabyte F2A85X-D3H is out of stock? I'm not to worried if it takes a bit over budget![]()
You get free postage with a years forum account too as far as I'm aware.
OcUK Forums members who have 250 or more posts and have been registered for over 90 days, or
OcUK Forums members who have been registered for over 12 months and made at least 100 posts
