- 24 Apr 2011
Desktop wallpaper? afraid no link m8. I created it myself
Yep.
Would you mind sharing it? Looks sick mate. Well done.
You should build a sliding shelf for the MIDI keyboard!
The difference from the start of this thread to the end is funny.
Indeed, are you?
just put in my new desk... loving it!!!
Very nice. Where did you get that wood from? How did you attach it to the wall? Where was the leg from?
I'm looking into replacing my glass Argos jobbie with a wooden fitted desk bolted to the wall, with a single support leg in the corner.
I'll be screwing through plasterboard so I know I'll need plasterboard fittings. However did you screw battens to the wall then screw the desk to the battens? What have you used for cable management?
Some updates:
New old TV Panasonic 46" TH-46PZ81B (Brought from neighbour for £200, could not say no!)
New case, Lian Li PC-7HX with stealth drive cover and Lamptron FC2 Fan controller. Did buy a Bitfenix Recon but I did not like that in the slightest
Runs completely silent since I swapped my old OCZ power supply for a new 1000W XFX. I hear the faint buzzing of the monitor over the computer!
I really should get around to buying a new chair
Then next on the list is watercooling after my final A-Level exams and then save up for a new graphics card and monitor
I would use the HDTV as the main screen, nothing beats big screen gaming.
