As I can`t use my PC at the moment, as I am swapping the 2500k for a 3770k, I thought I would put together a temporary system.
So using a GB P35-DQ6, a Q6600 GO and 2x2 OCZ DDR and a 612S cooler. Got it all built up, using the Psu in my sig and then I hit a snag. The fan on the cooler quickly spins up(then stops), the rear chassis fan just about turns(led light is just a flicker). The Psu fan turns over, then stops, if I leave it, it is just an endless cycle. Changed the ram for 2 other sticks, even tried with just 1 stick, same thing. So, I have power for about 10 seconds. Tried another 500W no name Psu, this only had a 4 pin Cpu power connecter, the board needs an pin, but I get the same result as before.
I have nothing else connected, no Gpu, hdd or optical drive. I have removed the Cmos battery, but I doubt that will help in any way.
Now my Psu was working this morning prior to me taking out the Cpu. And tbh, I have rarely heard the fan spin, certainly not as loud as it is now.
I`m going to take it all out later tonight, although I don`t think it is shorting.
I will check the pins behind the Cpu, to make sure there are no bent or damaged pins. The Cpu came installed when I bought it on the MM, 18 months later I finally get round to building it.
