The Xfire is just marketing hype really. The PCI-E lanes don't run in sync so adding the extra GPU is false economy. That's why I used the Z77X-D3H as it does it properly![]()
Ah, I didn't know that. Cheers.
 The cheaper cases 200/300R are not designed for watercooling fitting the H100 isn't an option. He could look at the Bitfenix Ronin which can take a 240/280mm rad in the ceiling but I'd want to use a modular PSU in it. That will cost more for the PSU though and you just might as well have had the 540 case with the non modular XFX 850W....it's all about balance
No worries fella.
Doesn't look like much of my advice has been taken in thoughThe cheaper cases 200/300R are not designed for watercooling fitting the H100 isn't an option. He could look at the Bitfenix Ronin which can take a 240/280mm rad in the ceiling but I'd want to use a modular PSU in it. That will cost more for the PSU though and you just might as well have had the 540 case with the non modular XFX 850W....it's all about balance
The H100 will have the paste pre-applied to it. CLCs are the easy way to get the watercooling look, the refurb'd H100 for £40 is a bargain it will cool better than an air cooler at the same price. If he is serious about doing watercooling he really REALLY should consider using the Carbide 540. It can take a 360mm rad at the front and more expensive cases can't even do that![]()
Many thanks for the advice even though it makes the whole thing even more difficult to decide upon!
Water cooling is not a necessity in my eyes. If air cooling will do the same job then that's fine. I was just unsure whether it was necessary or not. What are my options in this scenario and what would the cost now be? I presume I need some sort of heat sink and more fans?
Appreciate the advice!
You're quite welcome fella.
I wasn't having a dig at you I just seemed to be repeating myself a bit. The D3HP is NOT a dual GPU mobo really. If you know you'll never go that route then yes it's a good option. For a single GPU setup 500Wish is more than ok for the PSU going modular really helps too for cable management with helps airflow.
Single GPU setup with the i7K (do you really need the Hyperthreading?).
No kiddingQuiet case with a decent air cooler included. It can get confusing with so many options
but think things through. As I said work on your post count a little and if you live in the mainland UK you'll lose that nasty P&P.
 Once again, thankyou for all the advice and help. So after a lot of Google, thinking and headache I created a list borrowing heavily from the advice here. Please let me know if I have missed anything or am overlooking anything. I took the plunge and went for a larger case for more space inside for cooling.
YOUR BASKET
1 x BenQ XL2411T 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £239.99
1 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** £239.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £197.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x NZXT Phantom Enthusiast USB3.0 Full Tower Case - Orange/Black £104.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) £65.99
1 x XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £64.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £48.95
Total : £1,212.40 (includes shipping : £25.45).
Now, I have gone massively over budget here thanks to the monitor but this can be taken out (and might be despite being an excellent monitor so I have read). With this, do I have enough cooling and enough performance to play most games on decent settings? Single GPU will probably be fine for me.
Kind Regards,
Rexonon
 Many thanks gents. Sadly that Hyper 212 Evo is out of stock. Will I need to wait for it to become available before I purchase my basket? At the same time, is it difficult to remove the stock cooler and fit this instead? (I presume the CPU has a heatsink and fan on it already).
Whoops![]()
