I do love the el Toro juices, but I just can't justify paying for juice anymore. Besides, a chap I work with steeps his own tobacco and sorts me out 50ml here and there. It's quite nice, but it gunks up my rest in a matter of days. My VC mix is only on day 3 of steeping and I'm getting anxious already! I mixed up a wee 10ml batch of graham cracker that I'm going to dive into when I finally finish this lotus flower.
I say "Dekang" because they aren't in YNDK bottles and not cellowrapped like every other Dekang bottle I've bought elsewhere. Slightly dubious, will be interesting to see what it vapes likewhat grade mesh do you use with your rsst?
Is there anything new from smok which replaces the rsst?
Right guys, got my 3 protanks from fasttech earlier today...have to say it wook about 2 weeks from ordering to getting it so pretty happy with that.
I have some juices that at the moment im not using, i take it its fine to fill the tanks up and leave them to sit until i want to use them??, I mean im not going to have any weird taste or the tank wont go funny on me will it??
I have over a ltr each of vg, pg and distilled water. Im not sure what the shelf life is on the vg and pg, but would it be best to keep it in the fridge? Especially in the heat we have been having.
Im loving my AGA T2. After quite a few failed attempts at making a decent coil without any hot spots i found the 'precoil' method works best; in which you use a 3mm (i think) drill bit to fit the coil in situe. Slide the drill bit out and slide the mesh in. Works perfect every time (and i tried a few just for the hell of it because i was so amazed after all the failed attempts when not using a drill bit).
No, the RSST was the last SMOK have made for now. They keep bringing drippers out, like the SCAR.
If you're into Genesis atomiser's, have a look at the ATTY. It's a clone of the Z-Atty Pro and looks like it's going to be a bargain buy. My mate has bought one, he's just waiting on it arriving.
What's different about it?
Doesn't it take up much more room on the wick? I am intrigued, where did you order from?![]()
