- 6 Dec 2002
- North East
Recently purchased a BryShifter (quick shift) kit for my Focus ST. Finally got around to fitting it today and thought I'd share the photos and experience
The item itself is beautifully made, anodised in blue and tumbled so has nice smooth edges. The silver screws and ball-joint nicely contrast with the blue.
Fitting was fairly straightforward, bolt off and bolt on. The actually difference it makes to the gear change is fantastic - much more precise/solid and shorter for quicker changes. The difference is so much that I had to relearn where 5th/6th were located but after a minute of checking its all correct it becomes natural. Highly recommend one especially as you'll feel the benefit every time you change gear
Thanks for listening and hope it helps someone decide on getting one fitted
All the cool kids are on OcUK
