8GB Ram, 4GB usable ?
28 Feb 2013
Leeds
What is with this ?, i have googled it, and found nothing that resolves it, or maybe my brain has failed as im tired :(
does anyone have an answer to this ?, as id like to use all the 8GB i paid for :D
Thank you.
Jonnyp
EDIT: just looked at task manager, and thats only saying @total - "4093" ?
OP
28 Feb 2013
Leeds
What are your system specs and what operating system are you using (I assume 64bit)
sorry, forgot to mention that ...
FX6300
Gigabyte 78lmt-usb3
4x2GB corsair xms3 1333
windows 7 64bit ultimate (you was right ;) )
HD5770
WD 500 Green SATA 2 HDD
Fresh install of windows about 2 hours ago...
RHS
RHS
14 Feb 2013
Fife
Need some system specs from you and what OS you are using. Only so much anyone can do with a crystal ball :D
RJC
RJC
Don
29 May 2005
Kent
It appears your board has integrated Graphics, pop into the BIOS and disable this as your using a external card, I am wondering of your board has assigned some memory to this.
(You must have been a few seconds quicker :D)
OP
28 Feb 2013
Leeds
Ok, right!
Try a pair of memory stick individually to ensure you don't have a iffy bunch and perhaps check with Mem test (link below)
http://www.memtest.org/#downiso
but before i did a fresh install, it was fine and using all 8gb, do you think 2 sticks could have gone in the mean time ?
also, if i goto system properties , its saying "8GB, 4GB usable"
but in task manager. its only saying "total" 4093
confused much :confused:
RJC
RJC
Don
29 May 2005
Kent
Something is bugging me, I've seen this before but cant remember what! :(
Have you checked the BIOS since doing a fresh install?
Perhaps try a CMOS reset as well.
OP
28 Feb 2013
Leeds
think man, think!
i havnt yet no, im waiting for windows to download its 10,000,000 updates and install them, then i can restart
i will report back when i do :
15 May 2012
Louth, lincs
There is an option in msconfig regarding memory, think its on the same page where you select cpu cores, just a possibillity.
In msconfig its in "boot advanced options" the figure below max memory should be set to 0
16 Dec 2008
Lincolnshire
Last time I had this it was faulty memory, different brand of memory was ordered and the fault went away, funnily it was Corsair memory that went faulty on me, I replaced with GSkill memory I think it was and all showed and worked fine after, just had to rma the bad ones.
Caporegime
11 Jul 2009
BenefitStreetBirmingham
Test with only one ram stick installed,if it boots,pull the stick out and test the other stick in the same slot,then repeat the test for the other ram slot
You need to findout if you have a dead/faulty ram stick or slot
Btw onboard graphics won't reserve 4gb of ram,maybe 128-256mb tops
RJC
RJC
Don
29 May 2005
Kent
I still think that could be the onboard GPU has been re-enabled! :p
Hopefully you get this sorted, I need sleep!
