Did i just see you at the bank at the bp garage? Stalker mode enabled.
Gym gear? Check.
A3? Check.
You did indeed.
I was the dobber with the helmet and bicycle with a bright light on.
Watch the videos in the "How to Clean" thread. They are very basic explanations of how to get hip drive right and working before getting addicted and spending the rest of your gym life workout out how tog et evey last bit of hip extension out of the movement.
Start from a hang. That will force you to work the second pull.
Edit: also don't forget you're trying to do the two (three?) hardest lifts there are, and this takes time. Lots of it.![]()
