10 Aug 2013 at 19:39 #1 413x 413x Caporegime Joined 13 Jan 2010 Posts 33,660 Location Llaneirwg you can see a pentagon on the phone Shot was tested with a 50mm, 5 blade aperture lens It isnt always the same size it isnt on the lens its on a friends camera EDT, 50, not 500mm, typo also tried macro lens etc and still present Last edited: 10 Aug 2013
10 Aug 2013 at 19:44 #2 Raymond Lin Raymond Lin Caporegime Joined 20 Oct 2002 Posts 78,052 Location Wish i was in a Ramen Shop Counter Refraction from lens element? To eliminate if its dust on sensor. Put a lens on, shoot at something white and wave it around for 10 seconds or so at F 18 or something.
10 Aug 2013 at 19:46 #3 SeraphX SeraphX Soldato Joined 7 Jun 2010 Posts 7,166 Location Sussex Could be a dust bunny on the sensor
10 Aug 2013 at 19:53 #4 413x 413x Caporegime OP Joined 13 Jan 2010 Posts 33,660 Location Llaneirwg Raymond Lin said: Refraction from lens element? To eliminate if its dust on sensor. Put a lens on, shoot at something white and wave it around for 10 seconds or so at F 18 or something. Click to expand... you mean leave the shutter open for 10secs? SeraphX said: Could be a dust bunny on the sensor Click to expand... thought it might be this due to my newness to this, why does the mark change size with differing focus if it is in the body?
10 Aug 2013 at 20:21 #5 Raymond Lin Raymond Lin Caporegime Joined 20 Oct 2002 Posts 78,052 Location Wish i was in a Ramen Shop Counter al4x said: you mean leave the shutter open for 10secs? Click to expand... Yes, by waving it around you are moving everything else, if its dust then the dust on the sensor won't move, the stationary object is the dust. al4x said: thought it might be this due to my newness to this, why does the mark change size with differing focus if it is in the body? Click to expand... Hence why I said wave it around.
