- 24 Jun 2008
For sure, on my second set.. it seems the core of gears strips out. Got a slipper clutch on order.
I managed to snap the end off the locking grub screw on the collar on main rotor shaft, any ideas on getting it out bar cutting collar off with dremel ?
Let me know how you find the slipper clutch. I was looking at them as I mainly fly over grass so if I miss my landing pad (the box that the heli comes in!), I can easily get the tail caught up.
If there is nothing in the grub screw you can get hold of I think you might have to cut it off. Careful in there, I wonder whether sacrificing the main shaft might be easier.
