I wasn't the one throwing about blanket "almost" guarantees.
I'm just cautious, because I wouldn't really like to recommend someone something on the basis of an upgrade path that might be taken away.
I didn't mention Steamroller anywhere in this thread before you brought it up. I was recommending things based on what the developers have said. I'd be shocked if Steamroller does require a new socket, but even if it does, it wouldn't change my recommendation for BF4.
A Thuban second hand can be had for peanuts, and BF4 will use the cores, he's instantly got an extra 50% CPU at his disposal, and BF3 can max out a Thuban if it's low clocked, BF4 will be able to do the same.
Most cost effective upgrade.
I'm in two minds about SR, mainly because I see a lot of AM3+ recommendations based on SR upgrade path, and I wouldn't be surprised if AMD turned around and brought a new socket out.
I know it wasn't you that mentioned SR, but you pipped into the "discussion" then as soon as a counter point is made, you just go all whacko, just like now.
And my mention of SR made perfect sense given my original post.
I will fight tooth and nail to try and get people onto the intel setup.
I don't resort to personal insults in disagreements as you have been doing. I've made my points in this thread completely clear and they're completely reasonable. If they're so utterly wrong, I'm sure others will comment rather than you taking it upon yourself to do so every day.
