Fails to boot.
14 Oct 2012
Hi, i'm having PSU issues.
On another thread I said I already have these;
Here is my current build (What I already own);
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor **FREE SIMCITY PC GAME** (AD580KWOHJBOX) £99.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £68.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £49.99
1 x BitFenix Shinobi "Core" USB3.0 Gaming Case - Black £46.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £39.95
2 x Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) £6.98 (£13.96)
Total : £415.34 (includes shipping : £17.10).
And people spec'ed me the following upgrade;
YOUR BASKET
1 x VTX3D HD 7870 Black Boost Edition 2048MB GDDR5 PCI-Express Graphics Card £155.99
1 x Silverstone Argon SST-AR01 CPU Cooler - 120mm (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £28.99
Total : £196.38 (includes shipping : £9.50).
The problem is, that GPU has 2 6 pin power whilst my PSU only has 2 4 pin. On the box it also says requires 500w PSU. Why did people spec me this? or am I doing something wrong?
Your PSU is fine for that card, XFX make a good range of PSU
The PSU has 1 x PCI-E 6 PIN & 1 X PCI-E 6 + 2 for the GPU.
should I have a 6 pin for gpu and a 6 pin+2 for the gpu. because I can only find the 6pin+2, on boot the gpu fans spin...but I can't get output, no matterwhat gfx I set in bios.
XFX Pro 450W
Type of connector: Quantity:
20+4-pin ATX connector (550mm) 1
4+4-pin ATX12V/EPS12V (550mm) 1
8-pin ATX12V/EPS12V (550mm) 1
6-pin PCIe (570mm) 1
6+2-pin PCIe (600mm) 1
SATA (1 cable w/ 3 connectors) (550mm+130mm+130mm) 3
SATA (1 cable w/ 3 connectors) (370mm+130mm+130mm) 3
5.25" Peripheral Power Connector (1 cable w/ 3 connectors each) 3
(550mm+130mm+130mm)
(370mm+130mm+130mm)
3.5" Drive power adapter (+140mm) 2
Unit Dimensions(L x W x H) 140mm x 86mm x 150mm
I've searched multiple times and can only find the 6+2 pin. I'll take the PSU out tonight and see if it's hiding behind anything.
Do you have all the paper work that came with the Psu, you should have a list of all the cables and what they are for. Seems strange as all reviews and the XFX specs say 1x6 pin and 1x6+2 PCI-E cables.
Nope :( Got it 8 months ago and threw the box away after a month (silly me, but dont have the space), didn't check for things like that (mainly because I didn't know graphics cards needed 2 pcie power connectors)
I still have the overclockers order on my account, ao at least I have some sort of evidence that I bought it.
Perhaps you've got an older revision of the PSU that doesn't have the extra PCI-E cable.
You could always run it with a molex to PCI-E adapter though.
So despite getting the older version of the PSU, if I get the molex to PCIe adapter - will it run everything ok powerwise?
Yeah, if you use the one PCI-E cable and the other with the adapter.
Or you could ask ocuk if they'll exchange your PSU - it's possible I guess that you've got a defective one missing a cable :)
Past the 14 day period for returns. Not a problem though. I have bought molex to 6 pin adapter. Now just have to wait till it arrives.
Thanks
Since I don't have the original packaging then I doubt i'll get a replacement. Also, Overclockers already told me it's past the 14 day period.
If I have any trouble with the molex adapter and really need a new psu, I will put a bit more effort into getting a replacement.
Yeah, they can't say they won't replace something missing an attached part because it's past the 14 days. Just post in the CS forum if you want it replaced and reference this thread, since it's all explained.
