*** AMD FRIDAY: SO WHO WANTS A FREE BURGER & SOME EPIC AMD DEALS??? ***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK it's being a lot of NVIDIA these past couple of weeks with some amazing 670/680 deals with OcUK leading the way and causing the entire UK market to re-think its 6xx series prices and as such causing a huge price war, which in turn only works out great for our customers.
Certain competitors have tried to follow our NV pricing, promising to get stock, yet a week later still have no stock. OcUK guarantees stock and we won't let our customers down and our customer service is now beyond that of anyone elses in the UK, we are no.1 and have made huge improvements to our internal systems and CS resources which is clearly evident from us winning CustomPC 2013 award and massively improving our online ratings. Plus of course we have this amazing forum, something none of our competitors have with staffing manning the forum 24/7.
Well now were going to do the same with AMD, bringing you some truly incredible deals, expect our competitors to eventually follow. So here are the deals:-
First of all, here are the FREE burgers** courtesy of AMD:-
MSI HD 7990 6144MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
With more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 7900 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- HD 7990 is a dual GPU card
- Core Clock Speed: 950MHz
- Core Boost Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 2x384 bit / 6000MHz
- Load / Idle Board Power: <500W / <3W
- Power Connectors: 2x 8-pin required
- Display Outputs: DL-DVI-I, 4x Mini-Displayport
- 3yr Warranty
Was [£599.99] Inc. VAT
Only £499.99 inc VAT - WEEKEND ONLY PRE-ORDER PRICE!!
ORDER NOW
MSI HD 7970 GHz Twin FrozR OC BE 3072MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
As AMD is going to launch its latest HD 7000 series GPU on Jan. 9th, 2012, MSI also will release R7970 TF 3GD5/OC BE graphics card at the same time. MSI has exclusive GPU Overvoltage support through MSI's Afterburner utility allowing amazing overclocked performance from the get-go. Equipped with 3GB GDDR5 memory allows for the unprecedented memory bandwidth levels needed to run today visually hottest DirectX 11 titles at extreme resolutions across multiple displays. Stability is guaranteed through the use of All Solid Capacitors making sure the R7970 have an ultra-long lifespan even under the stress of continuous gaming. DisplayPort 1.2 and HDMI 1.4a connectors allows all new audio and video formats like Blu-ray 3D Stereo, "Deep Color" (for true natural color representation) and 7.1 High Bitrate audio to be presented on up-to six displays through AMD's Eyefinity Technology.
MSI's R7900 series graphics cards are the first graphics cards in the world to support the new PCI Express Gen 3 format. With a processor and mainboard that has PCI Express Gen 3 capability, users will be able to enjoy maximized gaming performance via the ultra-high 32GB/S bandwidth. The R7900 series graphics cards have also adopted the brand new AMD 28nm graphics chip to provide higher performance computing compared to previous generation 40nm products.
MSI's R7970 graphics cards are equipped with the popular Afterburner tuning software, allowing users to adjust the core voltage and improve overclocking potential. In addition, Afterburner also features bundled Predator in-game video capture, remote monitoring capabilities via mobile phone, as well as Kombustor GPU stress testing and other amazing features at no extra charge, providing an exceptional software suite for users of the HD 7000 series graphics cards.
MSI's R7900 series graphics cards support AMD's exclusive Eyefinity multi-monitor display technology. The expanded field of view is perfect for professionals and hardcore gamers. The new MSI R7900 series cards support next-generation Display Port 1.2 and HDMI 1.4a interfaces with stereoscopic 3D capability, as well as 7.1 channel lossless high quality TrueHD and DTS-HD audio formats, providing users with the best audio and visual experience possible.
MSI's R7970 has adopted all solid capacitors. The aluminum core is capable of maintaining a high degree of stability even when working under full loads over extended periods of time. With a 10-year lifespan, MSI rids users of concerns over potential crashes or delays that are caused by system hardware overheating, further providing users with the best computing experience possible.
Features:-
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1050MHz
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Memory Width / Speed: 384 bit / 5500MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was [£359.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** @ £189.95 inc VAT
Leading global mainboard and graphics card maker MSI today announces the release of the R7950 Twin Frozr III/OC graphics card. This graphics card features the latest AMD 7950 chipset with 1792 stream processors and 3072MB of 384-bit GDDR5 high-speed graphics memory. The greatly improved overclocking potential and stability increases overclocking performance up to 37.5%! The highly acclaimed Twin Frozr III thermal design with 8cm Propeller Blades fan setup for 20% more air flow and 8mm SuperPipe technology is used for cooling. Fan noise of just 30dB at full load provides gamers the most silence user experience, while MSI Military Class II components are used to give the highest quality and stability. For gamers seeking overclocking potential, cooling and stability, the R7950 Twin Frozr III/OC graphics card offers the perfect solution! This Boost Edition has an impressive base clock of 880MHz, but even more impressive is the Boost clock of 960MHz out the box.
- MSI Twin Frozr III Dual Fan Heatpipe Cooler For Maximum Cooling Potential and Low Noise
- 960MHz Core
- 3072MB GDDR5
- 5000MHz (effective)
- Warranty: 3 Years
**Latest Revision with 100% fan problem fixed, now PWM fan control works and the end-user can also use manual fan control**<
Was [£239.99] Inc. VAT
Only £189.95 inc VAT.
ORDER NOW
MSI HD 7950 OC BE 3072MB GDDR5 PCI-Express Graphics Card (R7950-3GD5/OC BE G) @ £175.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 830MHz
- Boost Clock: 840MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Was [227.99] Inc. VAT
Only £175.99 inc VAT.
ORDER NOW
MSI HD 7870 Black Knight 2048MB GDDR5 PCI-Express Graphics Card (R7870-2GD5T) @ £149.99 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
Specification:-
- Twin FrozR Cooler with black shroud
- Core Clock: 1000MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1280
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 3 Years
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards @ £129.99 inc VAT
Features:-
- Core Clock: 900MHz
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 3 Years
Was [£149.99] Inc. VAT
Only £129.99 inc VAT.
ORDER NOW
MSI HD 7790 OC 1024MB GDDR5 PCI-Express Graphics Card @ £94.99 inc VAT
MSI Graphics Card are the only one of meeting MIL-STD-810G standard. We adopt top components like Copper MOS, Hi-c CAP, Golden SSC, and Dark Solid CAP to ensure the best stability and quality. It brings perfect quality and longest lifetime to you.
Features:-
- Core Clock: 1050MHz
- Memory: 1024MB GDDR5
- Memory Clock: 6000MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 896
- Display Connectors: 1x Dual Link DVI, 1x DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£99.95] Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
MSI HD 7770 GHz Edition 1024MB GDDR5 PCI-Express Graphics Card @ £79.99 inc VAT
28 nm GCN (Graphic Core Next) Architecture
The new and 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in Processing Power. Crank the settings, devastate your enemies and bear witness to absurdly high frame rates with AMD Radeon HD7000 series graphics card-DirectX 11 has never looked this good. Maximum setting and crazy performance shouldn’t be a compromise. The AMD Radeon HD7900 Series with the new 28 nm GCN Architecture assures that it’s not.
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU (GPU communication-up to 16GB/sec in each direction), maximizing the performance from your GPU when paired with the latest platforms.
AMD HD3D Technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays / glasses / software.
GHz Edition
The gigahertz barrier has been broken. Armed with a stunning 1GHz GPU based on the revolutionary GCN Architecture, the AMD Radeon™ HD 7000 GHz Edition (Selected model) is quite simply engineered to annihilate.
Best Microsoft DirectX11 Support
The tessellation performance on AMD Radeon HD7000 is up to 2X faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good.
Cutting-edge Quad HD display support (4K Support)
The display resolution on AMD Radeon HD7000 series is quadrupled to the resolution of 4KX2K( 4096X2160 ) from the outputs of DisplayPort 1.2 and HDMI.
Discrete Digital Multi-Point Audio
The AMD Redeon HD 7900 Series is the first GPU that can simultaneously output multiple and discrete audio streams via HDMI and DisplayPort Output.
Enhanced Multi-GPU Capabilities
Triple or quadruple gaming power with AMD CrossFireX Multi-GPU technology. Increase your gaming performance up to 2x with AMD CrossFire technology, 2.75x for TriFire configurations, or with QuadFire configurations. With AMD ZeroCore Power Technology, the graphics card in slave modes will be switched off in idle to maximize the power saving.
AMD Eyefinity 2.0
The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better: The enhancements for AMD Radeon HD7000 series include: Stereo 3D-multi-display stereoscopic 3D support via DisplayPort 16K X 16K maximum display group resolution-output up to 268 megapixels per GPU.
- Memory Clock: 4500MHz (Effective)
- Processing Cores: 640
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£83.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
MSI HD 7750 2048MB GDDR3 PCI-Express Graphics Card @ £61.99 inc VAT
The AMD Radeon HD 7700 series is a new family of graphics cards targeting the enthusiast on a budget and mainstream users looking for increased graphics performance. It is based on the second family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN optimised graphics processing architecture. MSI introduces the worlds first HD 7000 series cards with overvoltage support! The new MSI 7750 offers you fantastic gaming performance.
Features:-
- Core Clock: 800MHz
- Memory: 2048MB GDDR3
- Memory Clock: 1600MHz (Effective)
- Processing Cores: 512
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£65.99] Inc. VAT
Only £61.99 inc VAT.
ORDER NOW
MSI HD 6670 2048MB GDDR3 PCI-Express Graphics Card @ £49.99 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6670 graphics processors offer advanced video and display features, Eyefinity multi-display technology, as well as AMD’s 2nd generation support for DirectX® 11 to give you the ultimate in “visual immersion” for your PC.
Features:-
- Memory Clock: 1334MHz (Effective)
- Processing Cores: 480
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI, 1x D-sub
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£64.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
MSI HD 6450 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £25.99 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6450 graphics processor is a next-generation visual upgrade that delivers Eyefinity multi-display technology, HDMI 1.4a for stereoscopic (3D) displays, Displayport 1.2 as well as 2nd generation support for DirectX 11 for the most versatile solution for everyday computing.
- Core Clock: 625MHz
- Memory: 1024MB GDDR3
- Memory Interface: 64-Bit
- Processing Cores: 160
- Display Connectors: 1 DVI, 1 HDMI and 1 Anologue
- HDCP Capable
- ATI Avivo HD
- Dimension 146(L)x22(W)x94(H) mm Size.
- Warranty: 3 Years
Was [£29.99] Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
FREE GAMES - ONLY WHILST STOCK LAST!!
Also when you buy a 7750 or higher from the above cards you will get the following FREE Games worth well over £100:-
- Farcry 3 Blood Dragon
- Crysis 3
- Tomb Raider
- Bioshock Infinite
These games are limited to the first 250 orders placed, as such we strongly advice you order quickly to ensure you get all the games listed above!
Oh and of course a FREE BURGER!!!**
**We have to apologise, our warehouse staff have eaten all the FREE burgers AMD supplied. :( ;)
OH INGLORIOUS BOTTOM BURPS!!!!
Fantastic prices- shame all my money has gone on a holiday and i don't get paid for a fortnight! aaaagh!!!!
I just bought (pre-ordered) the 6450 for a media PC but nothing to say that I got the games with the order. can you please confirm they will?
Also if I got another card will I get another set of games (a present for my brother)
**Edit** They are now showing in my order details. But if I buy a 2nd card will I get another set of games?
How does the MSI HD 7950 Twin Frozr III compare against the 670's? I've had a very brief look at reviews but they were put up against older cards.
Also, is more card memory the way to go? Skyrim seems to eat VRAM. Just trying to justify a purchase so the wife won't shout at me :)
Good deal if you get all those games with a £26 card as normally they only come with the 78/79 series cards
Although Crysis 3, the slideshow edition doesn't sound so fun. But a great card to give a bit more performance to a HTPC, while you get to enjoy the games on your main rig.
Ugh, extremely tempted by one of those 7950s!
Trying NOT to purchase a graphics card this month, it's being made very difficult!
It's been a while since I pre-ordered something from OCUK.
Is the cash taken immediately or when the item arrives in stock and is dispatched?
