My s4 came today loving it so far any apps that are a must?
nova launcher is one of the only ones I'd say are an absolute must but there's also a bunch of others that give the AOSP look if you're not going to flash it just yet.
Quick root. Titanium on, remove or freeze rubbish. Nova Launcher. Done. Enjoy.
U got a good guide on how to root, cant seem to find straight forward guide
trading my HTC one for one of these tonight, in black
Cant be reading the entire thread so in summary whats the most widely used rom? Still Wanam? and whats the best non flip case?
Cheers all
I think widely used is between wanam, foxhound, Pac, cm10.1 and the google edition.
Its horses for courses, if you're getting into flashing you might as well try them all lol!
Wanam (best flashed in conjunction with JBdomination theme) is trimmed down AOSP themed touchwiz, I think foxhound is the same without needing a theme? Not sure, thats the only one I haven't used.
CM10.1 and PAC are AOSP versions with a lot of tweaks, PAC especially.
And the google edition is the pure stock android experience but is actually very bare and basically gives you a smartphone. Not much else.. don't expect it to be watching your eyes or reading your heartbeat or having weird and wonderful DPI/UI customisations.
Same with the case.. just browse a bit and decide "best" isn't a word you can use for something as subjective as a case. Personally I use nothing, I just bought a bright orange battery cover![]()
you're best watching a youtube video, I find XDA pretty easy to use now but to begin with it comes across as what it is, purposefully unhelpful and technical.
That said it's the best place for all this sort of thing, just familiarise yourself with things like Odin etc via youtube, its what I did way back in the S1 days because you can watch someone do it, see how long each step takes and see what to expect.
rooting is much easier these days though!
I ran titanium back up but didn't have a clue what apps to freeze loltrading my HTC one for one of these tonight, in black
Cheers all
Complete settings revamp
IR added
New Bootanimation
Many fixes
will there ever be a way to get stock rom and then it gets the updates from google? chap selling one in the paper and says ....
"This is a new samsung galaxy s4, only opened it to install the 4.3 jelly bean.It has the stock version of android 4.3 -NOT a custom rom. This is actually transformed to a Google edition Samsung galaxy S4"
He says transformed so its not the Google Edition S4.
Sounds like he has put the just flashed the rom on to it.
You wont be able to get the updates directly from google unless its a Google Edition S4. Otherwise you will have to flash the updates yourself. Available from XDA
