My wife phoned the rspca and said she's only been up there about 12 hours (ffs)
How are they doing now?The 24 hours won't kill. it'll give it some time to think about what it's done.
Blimey your wife is up there too.How are they doing now?
.hosepipe. cats can drop a long way and land fine
She still appears to be stuck, although I'm not sure if she just can't be arsed coming down.
Sorry going off topic here...
But would the owner of the bike not have rights to remove the bike lock? I've heard of accidents before where someone's not paid any attention when locking their own bike to a frame and accidently locking in someone elses in the process. Cutting off their lock would appear to be rather extreme and could put you in the light of attempting to steal both bikes.
However if someone has deliberately locked a bike to a frame to prevent it from being moved, then surely that would be reason enough to remove it. I know full well if i had a bike worth thousands and that happened to me, I would get an angle grinder down to cut it off.
Cats can climb up but not down as they have no grip. Eventually it will get hungry and either jump or fall trying to get out.
Mine did the same not long after we moved, After a couple of days it just jumped from about 2 house heights landed on the grass and casually walked over to the food bowl like nothing had happened.
2 house heights, as in 4 stories? that's amazing
They have a non lethal terminal velocity so as long as they long as they land right then they should be ok.
Hahah please tell me they added those cat noises after!Forget the fire brigade... you need this guy!!
...or Uncle Ruckus![]()
To the terminal velocity thing, doesn't it have something to do with there tail and the way it makes there body turn while falling? Could be well of here...but that's rattling around my brain.
Through natural selection, cats have what is called aerial righting reflex which allows them to, given enough time, sense that they are falling incorrectly and spin themselves around like a sky diver or astronaut so that their feet are facing the ground. Having your main shock absorbers hit the ground instead of your back is crucial for fall survival. Interestingly, every animal that lives in the trees has a similar reflex, suggesting the same evolutionary process. You can see a shot by shot view of the aerial righting reflex below.
