- 29 Jul 2013
Thanks guys.
so in this day and age its only for the speed freak?Redundant Array of Inexpensive Disks. Short explanation: It's a way of making disks work together to make them bigger/faster/more resilient to data loss.
It comes from the days when hard disks were small, slow and expensive, and you had to link them together if you wanted to make them work better.
cool, thanks for the quick response. The water cooler picture intrigues me, would be cool if one of you could post it!
RAID can be useful for data redundancy as it protects against a disk failure but ultimately the disks will still be in a box (PC, Microserver, NAS box etc) and in one location so just because you use RAID doesn't mean you don't still need to back up important files.
Most people don't make the distinction between redundancy and resilience. RAID was never meant to replace backups and they are for different things.
For instance, RAID isn't going to help you if you accidentally format your system disk.
as the R in RAID stands for redundant, I don't think using the term 'data redundancy' is wrong especially when I explained that a back up would still be needed. My post could have been more elequent had I used 'data resilience' and 'data redundancy' but I think I made the point clear enough.That was my pointas the R in RAID stands for redundant, I don't think using the term 'data redundancy' is wrong especially when I explained that a back up would still be needed. My post could have been more elequent had I used 'data resilience' and 'data redundancy' but I think I made the point clear enough.
interesting, this makes me feel massively behind on all things RAID!!! I will attempt to understand as much as I can haha
potentially RAID 0 in the future, with 2 ssd's, but until I have that kind of disposable income it isn't going to happen! Although RAID 1 might be the more sensible choice. But no I haven't really got any thing in particular that I want to do as of now.Is there anything in particular you want to do?
