Does anyone know when a rare/legendary/set item drop at which point is the stats for the item is determined.
Are the stats determined straight away when the item drops or are the stats determined when you identify the item.
I reason why I ask is that say you pick up an item at nv=0 and therefore MF is low, the stats maybe be low due to the MF. But if the stats is determined when you identify the item you can effective pick up all items and wait until they your MF is higher before identifying?
D
D
