Can I use 205 width tyres to replace my 215s?
smr
smr
6 Mar 2008
Leicestershire
Hi,
Just a quick one... just did a tyre check for my new car (mk4 2008 Mondeo) and Ford's stipulation is 215/55R16 V93
My old car (mk3 2001 Mondeo) has 4 virtually brand new tyres which are 205/55/R16 V91
Would my old car's tyres be compatible with my new car? Unsure whether to keep them or not...
The Dealer has put four brand new Sunew YS112 on which I've since found out are a bag of **** and my old tyres are four virtually brand new Conti Eco Contact Premium 5s...
Dont imagine it would be a problem you can increase to 215 from most 205 rims so surely must be okay the other way.
speedodiff_zpseb98f71f.png~original
thanks guys,
I can just swap the wheels over myself jacking the cars up? Don't have to take them to a pro to get balanced or something again?
thanks guys,
Just swap them over. The wheels are already balanced.
Won't a Mk4 look weird on Mk3 rims though?
Check the fitment too, I have no idea about Ford wheel fitment.
Might be worth just getting the tyres done instead of the wheels. Unless you have steel wheels.
Do they have pressure sensors? If so they would need reprogramming.
But it should be fine. I am running some slightly smaller tyres on the front of my car to use up some tyres.
I don't know what to do now - my old car is advertised for sale with 12 watchers and a starting price of £250. Don't know whether to let the car sell and buy brand new 215 tyres with the money or just take the wheels off and stick them on my new car. Having just bought my new car it doesn't quite seem right to alter against Ford's recommendations iyswim.
If you really can be bothered, swap the tyres but not the rims.
You've got to question if it's worth the effort though.
What are the tyres on your old car?
Conti Eco Contact Premium 5s bought in March so decent tread and condition left on them.
how does width of tyre effect speedo?
Because the profile of a tyre (in this case the '55' in 215/55/16) is a percentage of the width. 55 per cent of 215 is a higher number than 55 per cent of 205 so the sidewall is slightly thicker.
Eco contacts and premium contacts are different but priced about the same in that size, about £80 fitted each.
I'd say it's worth keeping them, that said to swap all the tyres (not wheels) will cost a few quid as it's 8 tyres to fit in effect. I'd have a chat with some tyre fitters to see if you can cut a deal?
