Caporegime
 - 18 Sep 2009
 - Dormanstown.
I would think if Partners are knocking out FM2+ Motherboards now it can't be much longer.
Do you not remember AM3+
?Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
?Do you not remember AM3+?
I was waiting for you to come running in with that, its getting a bit worn out. just because there was a delay between AM3+ and Bulldozer is not to say because of that: its the norm...., there have been plenty of other platform launches since then with no delays, using AM3+ as a constant fullback position is getting a bit silly, IMO.
I've read that the boards are expected to be available more or less immediately after Kaveri is officially launched.
The Asus rep on bit-tech said that they're not planning any FM2+ ITX boards at all, which is weird.
Wouldn't touch Asrock.
And the only stuff I've ever had break personally is MSI stuff
And I've suggested a few Trinity Pre-Builts to people for gaming, if Kaveri is priced well, it'll make some excellent pre-builts.
AMD denied that it'd been delayed from what I recall.
