- 23 Feb 2010
- Hereford
Do you mean some vapers still have the odd ciggie or that people who vape exclusively are still 'smoking'?
If it's the first, the same can be said for any quitting device. In fact it's far more likely someone on patches or gum will return to the "one for old times" mentality than the vaper because the former isn't getting the simulation the e-cig user is.
If it's the latter then you need to go back to GCSE Chemistry class and ask what the difference between vapour and smoke is. You can't 'smoke' something that doesn't produce smoke.
I didn't mean smoke in a literal sense. But the habit of putting something in your mouth, inhaling, then blowing it out again is still the same. I take it you vape? Can you tell me if vapers could easily stop vaping and not worry about it?
Vapers still have the 'habit', therefore not really quitting completely.
