....and my current experiences explain why you shouldn't risk messing around with edu store discount.
I ordered some stuff off OCUK at the same time as placing my MBA order. For some reason, my bank got scared by OCUK and put a block on my card. Apple have only been able to take part payment and now my order is stuck in limbo with me doing call relays between my card company and Apple.
Would you want to do this if you had fraudulently used the edu store? I doubt it.
Can someone explain what 'Turbo Boost' is on the new MBAs? Seen that the 13" i5 will 'Turbo Boost up to 2.6GHz'.
I've been playing LoL on my 2011 MBP with an Intel HD 3000 GPU and with most settings on low I easily get 40-60 FPS.
The new MBA GPU is nearly twice as fast so running it well shouldn't be a problem. I think it's one of the better running games on Mac if you ask me.
Love the new mba. Just one problem, it runs wow at 70-90fps on average settings but the laptop gets soooo hot and fans kick in after about 10min. How can i prevent this?
I have the low end 13". It runs fine and smooth just overheats and fans kick in.Out of curiosity, which spec do you have? WoW is probably the only game I would play on it. Planning on getting the low end 13" model.
It has shut down twice. There is a massive patch update which is meant to solve this. 5.3It doesn't overheat. If it were overheating, it would shut down.
There is nothing you can do, as it is going to get hot. You're running an intensive task.
This whole overheating/running hot/burning/i5 vs. i7 heat thing is ridiculous.
I've been playing LoL for a few months on OSX and never had any issues. Only thing that annoys me is hot corners seem to decide to work sometimes so I end up flicking in and out of the game which is annoying!
Does anyone else have any experiences of playing games on this MBA? I've read the mac client for LoL is a bit hit and miss so would use windows for that but what about games like Diablo 3, Starcraft etc?
Not looking for amazing graphics and mega framerates, just looking for comfortable performance
