Before giving up, stop what you're doing and call it a night.![]()
Dat hotspot.
HALP cant get rid![]()
Get yourself down to a hardware store and buy a packet of 2.5mm stainless steel washers and either a 2mm or 2.5mm drill bit (whichever fits best in the wick hole) .
Remove 2 of the nuts on the AGA-T2 positive post and place a washer on the post. Screw down one of the nuts on top, save the other as a spare.
Remove your wick, coil your Kanthal around the top of the drill bit (the end without cutting thread) 4/5 turns is good. Stand the drill bit in the wick hole and connect the end to the negative screw and the other end over the top of the washer and trap under the nut, fairly tightly but you want to be able to slide the drill bit carefully out of the coil.
Pulse it gently and I'll pretty much guarantee you won't have a hot spot!
Roll your existing wick a little tighter, so you can slide it carefully through the coil into the wick hole. Provided the coil is just touching, lightly around the wick, another pulse should be perfick...
Juice up and enjoy!
