For an alternative analysis of the Crisis.
That's a terrifying thought.
So nothing to worry about here then? Move along?
There's no proof Chernobyl caused any birth defects. There's evidence it caused some thyroid cancer, but that can be offset by potassium iodide pills which I'm sure the Japanese people were issued with.
The effects of it were really exaggerated. Only 50 people actually died from Chernobyl.
http://www.who.int/mediacentre/news/releases/2005/pr38/en/index.html
As of mid-2005, however, fewer than 50 deaths had been directly attributed to radiation from the disaster, almost all being highly exposed rescue workers, many who died within months of the accident but others who died as late as 2004.
What he said.Yes, same as usual.
An obsolete nuclear power station in a bad location was hit by an extremely powerful earthquake and a major tsunami...and was undamaged. The cooling system, which is of a design which is no longer used, was damaged and the backup cooling system was inadequate for disaster conditions...and that still didn't kill anyone. Not one person.
The lesson from this incident should be that nuclear power has a remarkably low risk even in a combination of worst case scenarios.
There is a potential for catastrophe and it's right that nuclear power stations should be designed, built and run with an obsession for safety and with backups to the backups to the default-on safety systems, but if it's done properly it's quite safe (more so than using coal, that's for sure) and badly needed.
A modern nuclear power station would withstand even a major earthquake and tsunami without incident.
The leaking coolant tank is worrying only in that it happened at all, because it implies insufficient care was taken in the construction of the tank.
How long till these rods can stop being cooled, ie, why are they still hot?
It can be cleaned yeah, a few processes are in use for this.
Once the radioactive water has cooled. Can it not be used again?
Links for processes being used?
