indeed! Have you had a look at build 1 one?
Does anyone know when the pink S4 is coming out for the UK? GF wants one. Thanks.
Has the option been removed to turn off the lights on the capacitive buttons?
Also does anyone know which baseband is latest for the Three(3) network?
hmm. Not seeing an option. was there one before? I'm sure you've complained about not having the option before![]()
CM has the option for the buttons.
Does PACMAN Rom not incorporate the 3 roms fully?!
Has the call mute issue been solved in 4.3?
I honestly wish they would sort the camera out so i can go back to PA and easily apply themes across all the apps and system with one push of the button.
BUT, i doubt the camera will ever be on a par with TW![]()
Does CM10.2?
The camera will never be great on AOSP like it is on 4.3GE as that uses some TW Framework.
I do indeed hate the lights.
I complained that I couldn't find the option but did eventually find it in 4.2.2.
There seems to be an app someone has made as a workaround for 4.3 but why remove it from PACMAN/CM10.2. Bah!
I'm not sure about CM10.2 but 10.1 had the option. A quick look at the thread over at xda would suggest that CM10.2 does have the option for 3sec, 6sec, on and off.
You'd think they would rip the camera FW from GE4.2/4.3 and add it or intergrate it to AOSP by now.....
indeed.
Of course, you could always do it manually.
/sys/devices/platform/i2c-gpio.16/i2c-16/16-0020/leds/button-backlight/max_brightness.
change it to 0. save. boom.
Does anyone know if the uk is going to get the lte-a version with the snapdragon 800 as that is the one I am waiting for.
Go for the Note 3. S800 will have more breathing space there.
Thinking of getting the ZeroLemon 3000mAh battery - anyone here got one? If so what are your thoughts of it?
