- 31 Oct 2011
- Leyland
I agree ^^^^^ its been a long time coming but obviously you can tell he has spent the time well, planning and sourcing the correct bits and bobs.
Such an elegant and simple loop. Love the cpu block mod too. It's a great clean looking build, with performance to match. Great work dude
Your attention to detail is insane tbh! Great build.
looks beautiful mate
This has to be one of the cleanest, most tidy builds I've ever seen. Absolutely superb work. I can't wait to see the final photo's of the Power Supply fitted and it all up ad running![]()
Looks awesome mate....its such a shame that all GPUs have the power connector on the top though. It would be much better if you could get them on the bottom corner, so the cables are right out of the way instead of having to come up the side of your card.
edit... hang on a minute.... I might need to re-read the thread lol ..Your PSU uses that space... where are your HDDs? Have I missed an update?
Was there drilling involved? Or did you use a couple of mobo screwholes?
Your thinking 2D again mate
Try 3M Scotch Clear Mounting Tape #4010![]()
have you thought about getting another 240 for the roof?
Awesome stuff mate, really really like this build bud
Did you manage to source a windowed side panel?
Cheers,
G
I conducted the initial tests back in post #190
With my 2600K running at a nice sedate 4.6GHz I ran 7 threads on Prime95 and Heaven simultaneously for an hour straight, the hottest core on the 2600K never exceeded 75°C and the 680 never exceeded 42°C, the ambient room temperture at the time of testing was 23°C.
There is no need for a second rad
Cheers G, very much appreciated mate
Sadly no, despite Nanoxia having developed and made samples of side panels for the DS1 to my knowledge they have never put them into production...
In fact we did have to adjust the moulding/cutting for the Window-Sidepanels
as we did improve some small things.
Finally the sidepanels should be in Europe in about 5-6Weeks. Maybe we will
send some stock by air before, but this is under discussion at the moment.
amazingly clean build!!
stunning mate good work
The latest from Nanoxia:
