Seems I have it going at the momentit only BARELY glows alittle in the top coil when im not tiling as I have not got a full tank at the moment. Either way when it is taking juice it does not go bright its a really mellow LOW glow cant really see it and it seems to be fine. I got a 3 wrap coil at the moment just going to leave it for the moment see how it gets.
Is it suppose to get so hot though generaly in comparrison to a normal carto or clearo.
You're not not supposed to see the coil glowing if the wick is wet - since the juice should quench it as it vapourises. If you find the top turn starts glowing after a prolonged burn, it's only because the wick has dried out... If you're not getting any glowing when you tilt and wet the wick (you may find removing the fill screw helps wick faster), then that's fine, it's working as it should!
What resistance coil does the Aga have (put it on the Vamo and press & hold the right hand button)? Ideally you want 1.2 - 1.8, depending on the batteries your Roller uses (let me know).
I'm pleased you persevered - sorry I couldn't reply to your questions straight away, been at the hospital with my little dude most of the day.
The trick now is to keep the tank filled above halfway - otherwise you'll have to tilt the whole setup to keep the wick wet or risk a dry hit ('orrible!) when the coil burns on dry mesh.
Now you've got it working take what you've learned and apply it next time. You'll only need to recoil, mesh wicks last ages and you just remove and set fire to them if changing flavours.
But for the meantime, quit fiddling and enjoy it! Just keep the wick wet all the time the coil is burning.
As for your question - Yes, the AGA-T2 definitely gets hot - most rebuildables do, particularly when chain vaping and testing coils. Let it cool down you'll find your first vape from cold may be weak - it needs a little "priming" ; tilt the mod to wet the wick and activate the switch for a second or so before vaping - should give a good hit decent vapour!
