Its low profile ram so is ok.
Well. I Have 128gb SSD with Just OS and 2x3TB Raid0 HDD (6TB Total) for Games.
The reason I do this is IF something happened to 1 of them I wouldn't lose the lot. If I got a virus, I could just blitz my SSD with a fresh windows install and all my games would still be there from the get go.
Not to mention 500gb will fill up very fast if you have a bundle of games / DLC.
I have ALL my games installed (Some duplicates Steam/Origin) and I have 4.1TB left.
TBH I just think its a smart idea to keep your OS separate from everything else.
How do you share your basket like that ?
I'd consider 2x7970s too (MSI Twin Frozr). Only a little extra but better cooling.
What are the pro's an con's of 2x7970 vs 7990 ?
Only cooling? Or performance too? Will 2x7970's fit in my case?
A 7990 is two built into one, so you get two high end coolers instead of one reference. You plug one card into slot 1, and the second into slot 3, and it'll fit in any ATX case. Another benefit is that if one card fails, you can still use the other while you RMA it.
Would 850w be enough for 2x7970?
Yes it is.
How much do we have left in the budget for me to play with![]()
Done
Nerd p0rn complete.
