Whether its safe or not is a totally different debate and hard to argue at the moment (although I think it's much safer than tobacco) . . . But the thing I do know is that the actual vape cloud can set off smoke alarms, I tried it at home and blew out a vape cloud over it and off it went
If you obviously don't blow out a cloud on the smoke alarm directly you could get away with it *maybe* in the toilets but I would not swear to it.
I use a Nemesis mech mod and genesis atomizers so I do kick out a big cloud.
Question is can you vape on the flight, im off to Canada in a few weeks myself so wanted to know if its safe to vape??. Probably not as they will think its smoking when really it isnt...time to stock up on some nicotine gum i guess :/
Unless you fancy a tour of Guantanamo Bay I'd suggest not vaping on a plane, until Airlines see sense (and profit to be made) on ecigs![]()
I could never get away with vaping on the plane or any enclosed space. My device is a right smoke machine. So I can't see them allowing it in any public area. Just imagine the fog it would create and the disgust of other not vaping public.
Wife's family in Vancouver & Edmonton, so I've flown both Air TransAt & BA. Both didn't specifically allow vaping, but no one batted an eyelid when I used my cig-a-like. I minimised the vapour by holding onto the inhale for a few seconds (Stealth Vaping).
My order finally arrived from Fasttech today including my SVD
What VV/VW settings are others using? (this has a protank 2 on it btw)
I think Yas786 has a provari.....
1 x King's Custard
Bottle Size: 10ml
Strength: 12mg (Medium)
1 x Monkey Jizz
Bottle Size: 10ml
1 x Apple Pie & Custard
Bottle Size: 10ml
1 x MDV666
Bottle Size: 10ml
1 x Jester Juice
Bottle Size: 10ml
HELP
Just plugged the ego twist from FT in to a wall charger and the unit is flashing Green every 5 seconds
and the light on the battery stays on. Is this normal or?
Don't Panic!
Happens to us all and certainly nothing to be ashamed of![]()
Take the battery off the charger and remove the USB cable part too.
Give both contact points (on the charging cable and the battery) a thorough clean with either a cotton bud or kitchen paper towel and either cheap vodka, isopropyl alcohol (if you have it) or failing that, hot water.
Over time, especially with leaky attys, the juice can leave a sticky deposit on the head of the charging cable and make electrical contact difficult.
Dry any remaining cleaning fluid off the contacts (more dry kitchen paper and /or earbud )
Reconnect and plug in, the Twist should be screwed on just to the point contact is made. Should now be fine, otherwise unscrew/screw on tighter
Thanks I did that 20 mins ago but great info for others like me
Now the charger unit is red and flashies green every 5 seconds but the light on the ego twist has gone out.
Will leave it like this for an hour or so and see what happens.
Yeah, my Fasttech.com EGO-T 1100mah (branded Bydtech) occasionally does the same. Nothing to worry about, it charges just fine and continues to perform admirably.
In fact I've just spent the last 9 hours in the Children's Ward (seems we spend much of our lives there recently) and I've been popping into the corridor for a quick puff of Scope's Apple Tart in a recoiled ProTank at 1.8 ohms - got home and it's still going strong.
I had my Vamo in my grab bag, along with spare batteries, juice and the Ego charger, but no need. Wonderful little bit of kit.
