*** The Official Samsung Galaxy S4 Thread ***
Hi, I'm going to go and get an s4 tomorrow, how do people rate the Samsung cover for it and does anyone know the cheapest place to buy one from?
I bought the Spigen Slim Armor view and think it's the best phone case I've ever had way better than the Samsung flip I had on my Note and the Samsung flip my son has on his s3.
Think there mite be a problem with my s4 or thr battery it was fully charged at about 11 last night woke up about half 8 and it was at 75% and now at half 1 its at 9% that can't be normal? Only use is texting and wifi on
Mine just arrived - I'm as disappointed with the stock setup as I am impressed with the phone itself. They really should consider selling a pure google + essential Samsung features, not the bloated ****e it comes with. I use CM 10.1 on the SGS2, but I guess Foxhound is the best one for me to try, right?
They do we just don't get the Google edition over here unfortunately
Ah well, it's a massive shame, but I guess too few people care enough about it to make it worthwhile to Samsung. My new Nexus 7 is pretty much perfect at stock, where as the Galaxy S4 looks terrible and basically almost every aspect is worse than the stock options. At least it can be easy fixed, but they should really make more effort to make it work properly out of the box for those that can't easily switch the ROM and/or worry about the warranty etc.
Check what is running in the background.
I'm always closing down apps to help preserve battery.
If you want pure google just go straight for the google edition ROM, no need to be using something like foxhound to make it look more stock when you can have it completely stock if thats your bag.
FX/CM10.1/CM10.2/PA etc all have plenty of extras you might want however, I get that!
I am struggling to flash to the latest Probam. The OTA update downloads but that's it. I download the zip file manually but get an "unable to open zip file" error in TWRP
Thanks mate, I'm actually running CM10.1 on my old SGS2 and the decided on the Google Edition on the SGS4 before I saw your post (could have done without having to change the ROM on a brand new phone though). I really like CM10.1, but wasn't sure if it was reliable enough for my new phone, as I exclusively used the nightly builds (i.e. I don't mind crashes on my old, battered phone, but I'd rather the new one ran with as few crashes as possible).
I'll consider my options in a few weeks, as at the moment I'm short on time to work out what's best for me in the long-term. I appreciate the tips and will do some research at some point.
No worries, the beauty of the GE ROMs you'll find on XDA is they're built by google for the S4 so they're pretty flawless.
People have obviously started modding them a bit but they're fundamentally created from something thats retail ready so wifi/bt/camera etc all work fine.
I'm interested in this whole custom ROM thing, never tryed it before, From what it seems it looks very simple to do, but i'm so bloody confused as to what ROM to chose, i want something as close to plain simple stock android as possible, none of this touchwiz, or bloat nonsense, however keeping as many of the S4s features, like the camera, etc fully functional.
Can anyone suggest a ROM that would suit my needs and perhaps provide a link if that's not asking too much.:o
Pretty much the Google edition ROM for the reasons that Matt said. It's stable and takes away all the crap. You can get good guides by Google search, but all I can add is that I used Odin 1.85, rather than the Android developer tool. The techno buffalo one is clear and links too all required files for root and ROM change. I can help if you get stuck, 1h max if you take your time and go steady like I did. Can be done in 10 mins though.
Ive got an S4 on order and already downloaded Foxhound. I might be wrong but it seems to keep the phone close to stock but removing most of the stuff that you dont need.
Correct, it's a "clean" version of stock rom with performance tweaks. You'll still be able to use all the marketing features and such, but just less bloatware apps (many of which you can download yourself later if you wish)
Foxhound is the closest ROM available [as possibly Wanam which i dislike] to stock S4 rom.
Install the "Slim" version of the rom and it does not install any of the bloatware. You can always download any Samsung stuff later if you need to through the Over The Air Update. Its themed like Stock Android too.
Foxhound + Nova Launcher + Widget Locker = no TW!
There is no hint of TW on my phone because i hate it!
Google Edition Rom sounds like what you need. I've tried it and it is BASIC. So basic that i got rid of it after a day. Its fast but that's because its basic. The good thing about it is that the camera is still great unlike any of the AOSP roms.
If you want to keep as many of the S4 features then you want a TW based rom such as Fox Hound or Wanam. These retain the features of the S4 but remove the bloatware. Fox Hound is leading the charge with lots of updates but Wanam is dragging its heals in recent months.
FH: http://forum.xda-developers.com/showthread.php?t=2303239
Managed to update Probam to 4.4.3 last night.
Changelog
Code:
ProBAM 4.4.3
Update to android-4.3_r2.2
Sync CM last changes
Sync PA last changes
Mock SMS (simulate the reception of SMS on real devices)
Support LTE/GSM mode
Add Irda Service
Hardware acceleration
much more!
I have noticed it has changed the messaging icon the the blue one and now uses the dark theme! The settings menu has been changed to a more normal setup from the menus on the left then options on the right that it used. The option to save photos has been added to the camera. Good update for me
Your settings menu is still TW tabbed style. Hate it. :-P
I find it highly amusing when people cannot stand a certain layout (theme/skin) and then this drives them to levels of arrogance beyond that of a rock star. Android has done this to me! . Who do I think I am. Now... where are my meds
I think he was just being ironic - I don't like the TW settings menu either, but I don't literally hate many things in life.
