***The Vapers Lounge***
Status
Not open for further replies.
I think I may try to make a .5 Ohm coil or a micro coil using Silica next. On the other side of things im going to leave this coil as is for a while and enjoy that my second ever rolled coil works at sub 1 ohms and not mess it up completely xD.
Am I correct in saying you can get e liquid that doesnt contain any nicotine?
I actually gave up smoking nearly 3 years ago but I like the idea of just puffing on one of these as I would imagine it would be quite relaxing. Or am I kidding myself and its rather pointless considering I dont smoke?
There are 0 nic juices how ever you may not wana tempt fate and then end up maybe wanting nic. It might be your gateway back to using nicotine :O or smoking. Depends on you personally however.
Why would you want to go sub ohm? Some people do it because the are cloud chasers or want the throat hit. But running sub ohms can be dangerous to your equipment and your health. Plus it runs too hot and burns the juice.
I am only running a .9 Ohm coil right now. It is perfectly stable, its only when you go .7 or lower then things become dangerous specially when using 18350 batteries.
Im getting a nicer burn better flavour bigger clouds and a easier throat hit so i have to hit it for less time to get same results with larger draws.
Epic Clouds
Just got my replacement solid brass centre post for the bottom button on my sigelei 19b.
No more magnet, works perfect every time now :)
How many mls does every one typically use in a 24 hour period? I've been vaping on and off since this morning and have used about .7ml, is this a lot?
Not to worried, have another 29ml left in the pot! :)
Okay so this is how I have mine setup now opinions on the coil? Is it bad that its touching the base a little?
Also Tommy I seem to go through half a tank or a tank per day MAX on heavy vaping.
0.7mls... Impressive. I easily do 5mls a day:eek: But does depend on the device your using. When I was using a CE4, I didn't even manage to do 2mls a day.
[/IMG]
Not too sure mate, i wouldnt like it like that tbh
stick it on your vamo and see if its shorting? if not then carry on with it, if it is then raise it off the base
and i go through on average about 3mls per day
Doesn't matter what it looks like buddy - if it vapes well, with no hotspots, then don't touch it!
You can try to wrap a tidier coil the next time, but if it's working now, it doesn't matter if it's touching the base, or the coils aren't evenly spread etc...
Happy Vaping! :p
So, just wondering, can I buy the little collar from the Kanger Protank 1 separately and will it fit between my Protank 2 and an eGo battery?
Are there any good Dekang liquids about? The local petrol station has recently got a stand in with loads of Dekang eliquids all nicely retail boxed but I've heard mixed reviews (as with all liquids to be fair). Was wondering if any of them are good before taking a gamble.
It's an ego V3 starter kit!
I'd be very happy if I only vaped 0.7ml in a day! I normally get through 3-5ml depending on the device and setting. With the protank or cartomiser tanks, I tend to vape at slightly lower wattage so get through around 3ml/day but if I use an iclear30 which is dual coil, I get through a fair bit more.
It's normal to be vaping a bit more for a while if you lower the nic level and I tend to vape a bit more if the juice is particularly tasty!
I've got 4 Dekang juices, not keen, I also have 2 Dekang silver and 1 gold, they are pretty nice...
Status
