Road Cycling Essentials
Status
Not open for further replies.
That is true. I've had a lot of use from my current wheels and things are starting to go wrong. Occasional creaky front hub. Leaky rear freehub seal etc.
I'll take the opportunity to go away and rethink things but I'll be buying something soon :)
If they were the same (similar price):
- Canyon UL CF SL '14 11sp
- Scott Foil 20 (frameset) '13 11sp
Kind of annoyed that you can't fit mechanical/electronic to the Foil frames you buy a specific frame for one or the other although you can retrofit electronic to the manual Foil but requires drilling out the rear cable stop and voiding warranty. :(
Canyon:
Foil:
Status
