Road Cycling Essentials
Status
Not open for further replies.
Still not despatched my groupset that I ordered at the beginning of the week. You should be grateful you didn't order with PBK playtypus :(
Ah that doesn't sound good as its been removed from the site. My order was dispatched on Bank hol Monday arrived Tue :eek:
Quite often I get the dispatch email after my order has arrived from Planet X so wouldn't worry, you might get them tomorrow!
Same here, they're usually pretty good with getting things to me within a couple of days; not so much on sending out timely dispatch notifications.
Can't remember where I found the formula for tyre pressures, seen it around somewhere. Managed to google for it, seems to be quoted on a few websites.
I think the idea behind it is pressure too low and you run risk of pinch flats, pressure too high and the rolling resistance will actually increase. As said above it is better for the tyre to deform around defects in the road.
If you're pressure is lower than the formula says and you don't have problems then you are probably fine how you are. If higher then you may get a decrease in resistance by running a lower pressure, but lets the honest the difference is probably not that noticeable.
My tyres max psi is below what the formula says so I just run mine at 110PSI and haven't had any problems yet, I'm quite heavy at over 100kg to need as much pressure as I can get.
Came home early and my legs are dead. I don't know why I'm so knackered this week because I've only commuted three days :(
Anyway, now to catch up on the last few days of the Vuelta with a big bar of Fruit and Nut :D
I'm probably going to hell for this, but on my way home I saw a guy in workman's clothing and boots riding a Pinarello Dogma with Cosmic Carbones and I think Speedplay pedals.
I remember the article about the police pulling over that guy riding an expensive bike in "non-cycling" clothing and I can totally see why. Someone riding a Pinarello in toe-cap boots looks dodgy as ****. I gave him a long hard stare and he looked back at me with a guilty look. Should I have said something? I did consider taking my camera phone out but it was in my bag and the lights changed.
You should have made a citizens arrest, just in case.
:D
Status
