- 5 Jul 2012
- JARRA!
Good read, thanks!
Good read, thanks!
We've already seen some noticeable frame rate improvement in games with higher than 1600MHz speed memory with the Haswell CPUs due to the improved memory controller, I wonder what kind of performance difference would it make, if Haswell-E got a even better memory controller, and combine with the use of DDR4 memory...![]()
Get the impression [H] didn't have to much time to put that review together. Would have been good to see a high end 2/3/4 way GPU setup tested against haswell to see if the extra PCI-E lanes come into their own on X79.
The fail is strong with this one.
"Using our tried and true Kill-A-Watt method at the wall, the 4960X was 166 watts at idle and 353 watts at full load. The 3830K was 201 watts at idle, and 378 watts at full load."
1.4v to reach 4.6GHZ, what they smoking over at Intel, did they just spend the last 12 months on a beach somewhere ?
Moving past 4.5GHz to 4.6GHz proved to require a good bit more voltage, but that was all; 1.4v. You could about ~4.6GHz several different ways. 36x129 (4.644GHz) with a 1722MHz memory bus at 1.4v was stable. Pushing to 4.7GHz got close to the edge of stability using Prime95. I could get the Ivy Bridge-E to 46x102.2 (4.701GHz) with a 1600MHz memory bus and vCore at 1.44v but also had to push the VCCSA to 1.4v (stock is 1.2v). At 4.7GHz the system would BSOD after about 40 minutes.
what board did they test it on? ^^^
current x79 or newer
iirc they used the new X79 Deluxe.
Here is another hint in reply to one of my posts on Overclock3d
http://forum.overclock3d.net/showpost.php?p=681351&postcount=9
Things are not looking good for IB-E
I'm not sure it really matters tbh, most people are holding off until Haswell -E.
Haswell-E DDR4 new chipset altogether seems sensible even if your loaded!![]()
Oh well, at least Haswell -E is shaping up nicely, a proper upgrade.. 8 cores and DDR4. I'm starting to save my pennies now lol. 4770K is ideal until then ..
The worrying part about it is if Haswell-E follows the tread set by IB, Haswell and IB-E it will also be a poor overclocker.
If there are any superhero's at AMD reading this
We need you now more than ever, can you save the enthusiast PC market for us please.
