Moving back to Newcastle tomorrow, used to riding around country roads with not too much traffic.
Has anyone in Newcastle got any suggestions on routes around 10-20 miles? Don't really fancy too much riding in busy traffic. Was thinking about taking a look at hadrians cycleway out to tynemouth
here's a route I started doing
http://www.strava.com/activities/76699100
the newcastle side follows the hadrians cycle route paths.
I'm not sure what route the Gateshead side of the river follows though but it's all cycling paths apart from a few roads that aren't to busy.
some of the paths along side the roads are actually a shared cycling paths but they are poorly marked....
just look for the little blue signs on lampposts and don't expect the path to have painted markings. (some of the path is so skinny you couldn't split it into separate lanes)
heres an example of that
[look behind the bus shelter] It's obviously there to warn people not to stand in the way where bikes are going to fly past as you are not allowed bikes on buses
https://maps.google.com/maps?q=ne4+...mw8vKFXJOFzAwYJkASw&cbp=12,90.21,,0,13.8&z=17
some whole sections of the path are clearly fine for cycling but they aren't marked at either even so if you have never done them before you will find your self wondering if you're even supposed to be one them and then all of a sudden out of nowhere pops a cycling sign on the path
here's a longer version that goes down to wylam
http://www.strava.com/activities/77590777
but on the way back up into gateshead a lot of the "path" is more of a dirt nature trail which likely is not suitable for roadbikes with skinny tyres.
I've changed the course coloor to black where the nature trial path was you could probably adjust the route and just go on roads to avoid that bit but if you do the short version and dont go as far as wylam then you avoid that bit anyway
I saw around 50 rabbits doing that route really early in the morning :O
I've not tried going to to tyne mouth yet but from wylam to > tynemouth will be all the hadrians cycleway route I guess if you want to avoid the gateshead side of the river..
all the good routes seem to be over towards the newcastle airport but to get there you need to go across busy looking roundabouts so I haven't tried any of those ones yet.
Heres an example of one of those
http://ridewithgps.com/routes/1729048
the a167 roundabout doesn't look to bad but the the roundabout across the A1 near Kingston park looks a bit daunting for a newbie like me
There's this 40mile loop as well away from roads
http://ridewithgps.com/routes/3182192
But I've not tried that one yet either
