Can you not just put a g1/4 male/male barrel between the top and the res? Would join them together without tubing....
First of all - ABOUT TIME!
What exactly is the problem with the RES?
I would have done that Paul but it would make it look a bit fugly have ordered the correct res and it should be here in the morning .... feet up for an hour or two methinks![]()
Afternoon
SO dual D5 eh? I would love to know how much flow you would have!(Although flow is not as much effective in lowering temps in my view).
I have 2 x D5's as well but one is sitting in my goodies boxI want to put 2 x D5s in my loop just for the kicks but it is very hard to find a dual top(which is not made by EK).
Fatherhood is going well, Now I am trying to finish work and go home by 5pm - or erlier - every day
I guess I still have one more mod run left in me
Good luck with the build, show us your plan, how are you planing to put the loop?
Fair point T, it will look epic once done.
Have you gotten to the point of wishing you hadn't bothered yet? I get that a few times a build, have a sulk and a cig then get back at it![]()
I had res>pump>pump>GPU>GPU>CPU>MB>360>1080>280>260>res.
