I'm more than open to a build spec from you using the main components i listed one other part I was questioning was the mobo, is that a good choice for oc and sli?
Okay took onboard the suggestions you guys had, new PSU and upgraded to the Corsair 500r rather than 300r. It offers better cooling and is preinstalled with more fans so i could cut out the additional ones.
Parts I'm unsure about are the motherboard and RAM, the RAM above is out of stock so i changed for something else, am I fine with dual channel?
Thanks for the suggestion, will look into that mobo and will take your suggestion of SSD. Although i keep changing my mind every 5 seconds I think the 500r is the case I want to go for, not a huge fan of the bitfenix one.
Overall though, I'm good for compatibility and space, clearance etc?
