** SUPERB DEALS FROM NVIDIA PLUS FREE BATMAN & SPLINTERCELL GAMES TOO!! ***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right guys, our 670/680 stocks are starting to dry up, so unfortunately we can't hit some of the crazy pricing we have done simply as all the crazy cheap stock has being purchased and now all sold.
The sweetener is that for about the next 7-10 days anyone buying a 660 upwards will get both Batman and Splintercell, however Splintercell shall be all gone and ended in about ten days time, so now is a good time to buy to get both the free games.
Check the deals out:-
EVGA GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2781-KR) @ £509.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£529.99] Inc. VAT
Only £509.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 780 ACX Superclock 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2784-KR) @ £539.99 inc VAT
Features:-
Specification:-
- Core Base Clock: 967 MHz
- Core Boost Clock: 1020 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£559.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card (GV-N780D5-3GD-B) @ £527.99 inc VAT
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£539.99] Inc. VAT
Only £527.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 780 HOF 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE** @ £539.99 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
Specification:-
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£569.99] Inc. VAT
ORDER NOW
MSI GeForce GTX 780 PCI-Express 3072MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 770 SC ACX Dual Bios 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2776-KR) @ £329.99 inc VAT
Fast just got faster with the next-generation EVGA GeForce GTX 770, a high-performance graphics card designed from the ground up to deliver high-speed, super-smooth gaming.
EVGA is also introducing a brand new cooling design; the EVGA ACX cooler. This revolutionary double ball bearing fans with an average lifespan of 12 years. This is 4x longer lifespan vs competitors sleeve bearing fans! Not to mention this fan is silent, in factr it is 15% quieter on average!
The EVGA GeForce GTX 770 is stacked with unique gaming technologies like NVIDIA GPU Boost 2.0 that make it fast. Really fast. So nothing will hold you back from taking on - and dominating - your most challenging games.
Specification:-
- Dual BIOS Version
- Core Clock: 1111MHz (GK104)
- Core Boost Clock: 1163MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2222MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£359.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
The GeForce® GTX 770 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1059MHz (GK104)
- Core Boost Clock: 1111MHz
- Shader Clock: 2118MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£329.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
Features:-
Specification:-
- Core Clock: 1137MHz (GK104)
- Core Boost Clock: 1189MHz
- Memory: 4096MB GDDR5
- Shader Clock: 2274MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£379.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Lightning 2048MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
Features:-
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Shader Clock: 2300MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 250 watts at stock speed)
- Warranty: 3 Years
ORDER NOW
EVGA GeForce GTX 760 SC ACX 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2765-KR) @ £199.99 inc VAT
The EVGA GeForce GTX 760 is the new weapon of choice for gamers - a powerful graphics card that gives you the fast, smooth, quiet gaming you're looking for in all your favorite titles.
EVGA is also extending the award winning ACX Cooling to the EVGA GeForce GTX 760 line. With a 40% increase in heatsink volume, the EVGA ACX is more efficient at dissipating heat, allowing for 15% lower GPU temperatures.
Even the fan blades are of the highest quality; with a 700% increase in strength, and 25% lower weight when compared to competitors. This makes the fans 20% more efficient by requiring lower power levels. EVGA is also using double ball bearing fans which offer a 12 year lifespan, 4X longer when compared to competitors!
Specification:-
- Core Clock: 1072MHz (GK104)
- Core Boost Clock: 1137MHz
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 2116MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£209.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
MSI GeForce GTX 760 OC 2048MB GDDR5 PCI-Express Graphics Card @ £191.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
This is serious equipment for the serious gamer.
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1072MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£199.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 760 2048MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
The OcUK GTX 760 is a powerful, feature-rich card stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Specification:-
- Core Clock: 980MHz (GK104)
- Core Boost Clock: 1033MHz
- Shader Clock: 1960MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£185.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
MSI GeForce GTX 680 OC Twin Frozr 2048MB GDDR5 PCI-Express Graphics Card with FREE Batman & Splintercell PC Games @ £239.99 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Features:-
- Propeller Blade Technology generates 20% more airflow than traditional fan design
- Dual 8 PWM fans with SuperPipe technology provide better heat dissipation.
- 22c cooler and 10.2 dB quieter than reference design!!
Specification:-
- Core Clock: 1058MHz (GK104)
- Core Boost Clock: 1124MHz
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Shader Clock: 2012MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 3 Years
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
MSI GeForce GTX 680 Power Edition 2048MB GDDR5 PCI-Express Graphics Card with FREE Batman & Splintercell PC Games @ £259.99 inc VAT
This MSI GTX 680 Power Edition is almost identical to the record winning MSI GTX 680 Lightning, but here at OcUK we consider this card to be even better than the Lightning for two main reasons. The first being that this card cost far less, but the second that this card has Dual DVI connectivity.
Very limited stock and a crazy price!
Features:-
- GPU Reactor
- Xtreme Thermal
- Military Class III Components
- Triple Overvoltage: adjust the voltage of GPU, memory and VDDCI to unleash the potential of graphics card
- Offer 16 degree cooler and 6.7dB quieter than reference product
- Enhanced PWM Design: provide higher overclocking capability and better stability in peak load
Specification:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1084MHz
- Shader Clock: 2038MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x DVI, 1x HDMI & 1x Displayport
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- With FREE Splintercell Blacklist PC Game
- Warranty: 3 Years
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
MSI GeForce GTX 670 OC Twin Frozr Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Transform your gaming experience with the GeForce GTX670 Power Edition graphics card from MSI. Featuring the award-winning Twin Frozr thermal solution, innovative Military Class III component design, enhanced PWM configuration, and MSI's proprietary Afterburner overclocking suite, own the best graphics hardware with the GeForce GTX670 Power Edition from MSI.
The GTX670 Power Edition features the industry-leading Twin Frozr IV thermal design. With 8mm SuperPipes soldered to an all-copper, nickle-plated base, twin 80mm Propeller Blade fans, and a high density heat fin stack, the GTX670 Power Edition is up to 16C cooler than a competing design.
It also features Dust Removal Technology, which spins the fans in full reverse for 30 seconds at system start to minimize dust buildup and ensure optimal thermal performance. The GTX670 Power Edition also features a full-length heatsink that cover the front of the PCB, cooling and protecting critical components on the graphics card while preventing PCB flex.
The GTX670 Power Edition features a robust 6+1 phase PWM design that delivers 25% more current to the GPU versus the reference design for maximum performance and stability. This enhanced allows for better GPU Boost performance under load, and provides maximum power delivery and stability for gaming and overclocking.
MSI's Military Class III components meet a more stringent testing standard than industry-wide electronic components.
Utilizing the US DoD MIL-STD-810G testing protocol, Military Class III components are rated to run under the most strenuous conditions to meet the highest levels of performance.
These components include: Hi-C CAP -- Low profile tantalum core capacitors, more than 10 times the lifespan of traditional capacitors with 15 times less power leakage Solid State Choke (SSC) -- Pure iron core choke with high working current, designed for overclocking All-Solid CAP -- Nickle-plated cover for longer endurance, up to 10 years lifespan under full electrical loads
Features:-
- GeForce GTX670 GPU
- 1344 CUDA Cores, 1019MHz Base Clock, 1097MHz Boost Clock
- 256-bit 2GB GDDR5 RAM at 6008MHz
- Innovative GPU Boost, NVIDIA PhysX, NVIDIA 3D Surround technology
- 3-way SLI, DirectX 11.1, PCI Express 3.0>/li>
- Twin Frozr IV Thermal Solution with Dust Removal Technology
- Enhanced PWM Design for increased GPU Boost headroom
- Full overclocking and monitoring via MSI Afterburner software suite
- Military Class III component design for maximum performance and power efficiency
Specifications:-
- Core Boost Clock: 1079MHz
- Processing Cores: 1344
- Shader Clock: 1930MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
MSI GeForce GTX 660 Black Knight 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
The MSI GeForce GTX 660 graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:-
- Memory Interface: 192-Bit
- Processing Cores: 960
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Asus GeForce GTX 650Ti DirectCU 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
If you're passionate about first-person shooters like Call of Duty, massively multiplayer online games like World of Warcraft, or real-time strategy games like StarCraft II, then GeForce GTX is for you. Turbocharge your experience with the powerful performance of Asus GeForce GTX 650 Ti and enjoy the latest games in full 1080P HD with this next-generation NVIDIA Kepler architecture-based GPU.
Features:-
- Dual fans increase thermal efficiency with 11% better cooling and 14% lower noise emissions
- DIGI+ VRM with Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
- NVIDIA® 3D Surround™ technology to expand displays on up to four monitors at once
Specification:-
- Core Clock: 928MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 768
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI, 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£119.99] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Asus GeForce GTX 650 DirectCU 1024MB GDDR5 PCI-Express Graphics Card @ £89.99 inc VAT
NVIDIA launched a new era in gaming with the NVIDIA® Kepler™-powered GeForce GTX family. Now, there are two new ways to experience the fastest, most efficient and powerful generation of graphics cards for yourself. Take your gaming experience to the next level with the GeForce® GTX 660-the weapon of choice for gamers-or the powerful yet remarkably priced GeForce GTX 650. Choose your weapon. Game on!
Features:-
- ASUS DirectCU cards operate 20% cooler and much quieter than reference in every model.
- DIGI+ VRM with Super Alloy Power delivers superior efficiency, reliability, and performance.
Specification:-
- Memory Clock: 5000MHz (Effective)
- Processing Cores: 384
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI, 1x Mini-HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 100 watts at stock speed)
- Warranty: 3 Years
Was [£95.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
MSI GeForce GT 630 2048MB GDDR3 PCI-Express Graphics Card @ £47.99 inc VAT
Every PC deserves great graphics. NVIDIA GeForce GT 600-series graphics cards deliver premium multimedia performance-every time. Trust NVIDIA GeForce GT 630, 620, and 610 dedicated graphics for a faster, more immersive experience in your favorite applications.
- CUDA Cores: 96
- Core Clock (MHz): 810
- Boost Core Clock (MHz): n/a
- Processor Clock (MHz): 1620
- Memory Amount: 2GB DDR3
- Memory Interface: 128-bit
- Memory Clock (MHz): 1000 (2000 effective)
- Memory Bandwidth(GB/sec): 25.6
- Texture Fill Rate (billion/sec): 13 / 13
- Direct X 11
- Outputs: Dual DVI-I / HDMI / VGA
- Power Connectors: None
- TDP: 65W
- 3yr Warranty
Was [£49.99] Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
MSI GeForce N210 SILENT 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £16.79 inc VAT
Graphics processing has become an essential ingredient to the modern PC. Nowadays, we simply demand more from our PCs. If you want to enhance photos, edit videos, watch movies, play games, or if you simply desire a Premium Windows® 7 Experience, the NVIDIA® GeForce® 210 graphics card brings impressive graphics processing power to your PC at an incredible value.
- Core Clock: 589MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1000MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 16
- Shader Clock: 1178MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 3 Years
Was [£17.99] Inc. VAT
Only £16.79 inc VAT.
ORDER NOW
Remember with 660 upwards you get both Batman and Splintercell games which have a combined value of approx £50, resulting in some epic deals here.
Also we think good prices on graphics and memory could come to an end in coming weeks as 30% of the worlds production on memory has ceased today with explosions happening in Taiwan in Hynix memory factory.
Thank just want I needed a 670 on offer again.
Can I ask as I've read on here and else were that people have had problems with the MSI 670 the above one, are these from the fixed batch by any chance ?
In the last few weeks we've sold over 500 of them, and had like 10 reported issues, as such there is no issue, just as with everything there is a small risk of getting a faulty card or having a compatibility issue.
Cool ok im ordering rite now thanks, now to find a 1080p monitor.
Question, I have a 600 W OCZ PSU, if I buy 2 of the MSI 670's will I have enough power?
Someone in the graphic card section said that 2x of his 670's took just over 440W can not remember the exact Watt's but was just over 440W and he had a 700W+ psu
Muwhahah a that msi 670 people oc is £2 more than when I got it on Sundays from ocuk. A 680 would have been nice though.
Have the Batman keys ran out? My 680 arrived with Splinter Cell but no Batman
If I'm rite Gibbo said they are starting to give the batman out due to giving out the last of splinter cell so I would not think they would run out of the batman ones.
I would contact them and ask as I remember someone had no codes and got them back from contacting OCUK
