The thing is, your gpu's will rarely hit maximum usage, apart from when you're benching. It'll work hard enough for the settings you've select. You've probably got vsync on to, which means it'll only push to 60fps (depending on your monitor).
See what you are saying, I play pretty much all my games with V-Sync off. Some games get higher usage than others, normally more when they are more demanding.
Tom
