Going to have to wait a while to be able to check if my main computer is still alive.
But I'm pretty sure the power supply is screwed.
The spray of sparks out the back, loud bang, dead fuse in the plug and tripping of the circuit breaker suggests nothing good.
Also a chunky resistor shaped thing behind a plastic shield behind the rear grille appears to have exploded violently, shattering the plastic shield and punching a small bit of it through the grille in a biscuit cutter fashion.
Probably the source of the black bitty things that came out with the sparks.
Was reminded of this video:
On the other hand it's lasted 4 years since 2009.
On the other other hand it's got a 7 year guarantee
It has often made a moderate electrical "pop" when switched on to the mains but since it never seemed to affect performance I put it down to the switch inside being crude but functional.
They seemed to be closed til monday so nothing to do but sulk on my spare computer.
