Worth mentioning if you update to MGG/MF8 you'll have flashed a locked bootloader and can't go back and downgrade (as of now). And that included your nandroids.
Please tell me you're incorrect
I've been on this for a while now; stock and pre rooted.
makes sense, this is in response to security concerns.. android is much less secure and the fact we all root and hack and flash and then try running banking apps perhaps points to the necessity for this.
Can't have it both ways I guess!
Which way would you prefer?
Sorry typo, MGG/MH8 is the latest (and OTA) with the new lock. Your's says permissive and an MGA build, MF8 baseband (modem) so looks ok. If you ever want to ever go back keep an eye on the base and bootloader included before you flash.Please tell me you're incorrect
Chainfire
Shared publicly - Sep 4, 2013
CF-Auto-Root for the new SGS4 I9505 firmares (GG, H8, ...)
The new firmwares that came out today have SELinux enabled and set to restrictive. This generally made SuperSU sad.
Other nasty side effects of these ROMs include a new bootloader, a new warranty status inside said bootloader, the apparent impossibility to downgrade after having flashed the wretched bootloader, and a bad taste about Samsung in general.
I guess this all KNOX related or whatever, seeing as it was much hyped in today's unveilings and the ROMs were also released today.
It took all day but it seems like I have SuperSU (now v1.60) running properly(?) again, and I've made a new CF-Auto-Root package for it. Undoubtedly, after I get back all your reports about how it doesn't work at all or even a little, I will update the other CF-Auto-Root's, the flashable ZIP, and the Play Store sometime tomorrow. But not tonight - tonight I am le tired.
While this version should now be compatible with all sorts of Enforcing SELinux shams and other false-sense-of-security-inducing hypeware, it doesn't actually disable any system components. As such, every time you use root, you'll get a nice popup about how your system has been compromised by the nastiest of all attackers (namely, you). To get rid of this annoyance, adb shell or Terminal Emulator this command (after running su , of course):
pm disable com.sec.knox.seandroid
That's about it. Oh yeah - don't run Triangle Away or Mobile ODIN on these firmwares until I've updated them, or your phone will explode. Enjoy!
MG4 build, MG1 modem, Australian? Anyway, yeah that's pre MGG/MH8/MH5 so no don't OTA. And don't assume any custom rom has the bootloader removed.https://www.dropbox.com/s/z36dejixcupahjf/2013-09-09 16.11.21.png <<<<<<<<<<<<am i safe?
i assume all what it means is that i just dont do any OTA updates from now on and just flash a custom rom as they will remove all the nasty bits?
i know nothing about these things yet and am finding it hard to keep track!
im all rooted now though, and have a custom recovery installed.
just need a memory card and then to decide what rom to flash!
Its got to be done as mine is slower than my old HTC one s atm
Is unlocking the S4 easy? If it is then great, If it's not then I cba, can't see any reason to root it unless it's easy as the phone does everything and the battery life is ok.
It's as easy as an easy thing. Easier if anything.
??!!my phone is actually from the EE store in the uk??!!
What custom rom would you recommend ?
Pref need a rom that offers 2g network selection as some areas im in have awful reception
Also is there a easy way to understand all these big long numbers and codes and base bands stuff.
I understand that im on a low one? but when i go on XDA it says i need to update to the latest baseband ?XXUDMH8 which i thought according to what i read here is a big no no?
cheers for any help, im itching to flash but dont wanna stuff it up!
GT-I9505 Modified Stock ROM - CWM/TWRP/PhilZ flashable ZIP:
Model: GT-I9505 (4.2.2)
PDA: XXUDMH8
PHONE: XXUDMH8
CSC: OXXDMHA (29 codes)
Pre-Rooted ROM: Downloads: <<< Android Host >>>
Baseband is the [URL="http://forum.xda-developers.com/showthread.php?t=2192025"]modem, and you can flash that. Make sure it is that though, it's just a tiny file.
And it's a standard feature to select network providers.
